Trans info?
Old Oct 19, 2012 | 06:37 AM
MarkG.'s Avatar
MarkG.
Trans info?
Hey, just out of curiosity, does any one know what kind of power a t-9 trans can handle?(such as a modified flat head). what about the rest of the drivetrain? Thanks.
Old Oct 19, 2012 | 08:55 AM
4tl8ford's Avatar
4tl8ford
Which one
The T9 Truck transmission
or
The newer T9 fromvery small Fords that were made from pot metal
Old Oct 19, 2012 | 10:54 AM
MarkG.'s Avatar
MarkG.
I mean the t9 truck trans. my 51 f5 has what i believe is a borg-warner 4-speed spur type/t9 trans. where they used in 51? i have info that says they were only used from 1930 to 1950. what would it be if they were not used in 51. my trans i deffinantly a four speed un-synchronized though. and like asked before what kind of power can my trans and drivetrain handle?
Old Oct 19, 2012 | 11:36 AM
F6Guy's Avatar
F6Guy
From what I have read the t98 was an optional transmission in the f1 thru f6 trucks and offered as standard equipment behind the 254 big six in the f6 ford only. The t9 was available at least till 52. I parted out a 52 f5 with one in it. The ratios are the same as a t98. As far as its durability I can assure you that it can handle whatever a highly modified flat motor can throw at it. Its life will be dependent on your ability to shift it.
Old Oct 19, 2012 | 02:47 PM
fifty-two_f1's Avatar
fifty-two_f1
I think what you mean is the "59T"??? (i could be wrong) That was the spur gear. The T98s as F6guy stated was offered, but tough to find. They have all the same gears as the 53 and on T98s. But yeah the spur gear type trans is TOUGH. People hate them because they are not syncronized, but slow down and take your time, youll get the hang of it
STEVE1103
Flathead V8 & Flathead 6
Feb 26, 2006 07:19 AM
gar
1947 and Older Ford Trucks
Nov 23, 2002 02:14 PM
