if you have the camper pkg you have the same springs as a f350
The overloads seem to be designed poorly, by the time they are touching and you are going to be sagging quite a bit worse then a f350 would be I'm guessing? Anybody know how many inches it takes before the overloads start to work? I've been sagged 2 to 3 inches, and my overloads look they have never touched.
I called my local dealer and asked about F350 blocks. I was told that the only difference 250/350 is the blocks. They can install them on my next oil change for $350 parts & labor.
Did that price include the overload spring,and the perches the overloads will come in contact with?
How far off the bump stops do yours sit when you're empty? I think the 3/4 ton and the 1 ton dually both use the 2" blocks under the leaf springs.[/QUOTE]
If the truck is completely empty and with the stock fuel tank it sit about an inch and half above bump stops. with all the stuff I have in the back (tool box, 9000lb warn winch, chain and straps, 15 ton bottle jack) with a fuel tank of fuel in the titan tank I have about 1/4 to 1/2 inch when the tank is empty I have about 1 inch.
Just thought I would ask considering the discussion here.
The ones on mine are small and yellow.
Just wondereding about that. Any comments on the install and effectiveness
I was wondering about these too, a user has a video of his f250 with these installed plus two extra leafs per side. The video is of the truck being loaded with a pallet of bagged marble, pretty impressed by the video.
Yes the only thing I had to do is jack up the back up of truck to get more space between the stops take out one bolt put block together and install took about an hour maybe a little less
How does increased block height change payload? If f250 is 2", how is the only difference bigger block giving higher payload in f350? I would think leaf rate is also higher.
