1990 Ranger 4.0 MAP sensor question...
Old 07-12-2012, 10:46 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Still trying to get this truck to run right. I recently added some new ground cables throughout the truck. It seems to be running more consistant, however fuel economy and performance is suffering. You really have to stomp on it to get this thing to move, it feels lazy. I am looking into possible MAP sensor problems. If what I am looking at is the MAP sensor it's located on the firewall almost directly above the coil pack. It has a 3 or 4 wire (can't remember exactly) plug in it and what looks like maybe a vacuum port on it. My question is on this sensor, is it supposed to have a vacuum line on it doesn't look like it's had one on it) ; and where should it be connected to? I have searched high and low and cannot find a good diagram to see what goes where. Anyone have any underhood pictures of their 90-92 Ranger 4.0 engine compartment? Any help and advise is appreciated!
John
Old 07-13-2012, 09:53 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
It should have a vacuum line, hook it to any good vacuum source that does not have a check valve or vacuum reservoir on it. Direct to the manifold is best.
Old 07-13-2012, 11:59 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Pulled a 22 code on my 87 2.9 about a week ago & replaced the MAP.
On my 87 the vacuum hose connects to the intake just behind the throttle body.
kirbykoon
10-14-2010 05:23 PM
pickncrew
03-17-2008 10:34 PM
pud
08-27-2006 10:55 PM
southsidej
08-29-2005 11:43 AM
gdoggy
07-29-2003 09:36 AM
Quick Reply: 1990 Ranger 4.0 MAP sensor question...
