AC suddenly quit.
Old Jul 12, 2012 | 05:49 PM
draboo's Avatar
draboo
AC suddenly quit.
We took a 250 mi round trip yesterday and the AC was working fine. Took a short trip today and no AC on the way home.
I checked the AC clutch fuse and it looks fine,but changed it anyway with no results. My question is this:
In the manual it says fuse #23 is for Climate Control, deisel engine only. Is this for the heater/AC fan/blower? The fan works fine, just no cold air.
Brad
Old Jul 12, 2012 | 06:26 PM
69cj's Avatar
69cj
electronic climate control? Is the comp. clutch pulling in? Crystal ball is out of order today.
Old Jul 12, 2012 | 09:59 PM
zhilton's Avatar
zhilton
Do you have the electronic climate control or the manual *****? Wouldn't hurt to check fuse #23 if it's in there. My Lariat doesn't have the automatic/electronic climate control. But I don't remember if it was an option for the Lariat or if it was only the KR that year. Do you have all the fan speeds or only high & off?
Old Jul 13, 2012 | 09:21 AM
draboo's Avatar
draboo
I see what you are getting at..I have all the speeds, like 3 or 4, on the ****, so fuse 23 would not be in use.
I think I ll just bring it in and have it checked. Even if I do figger out what the problem is, I do not have the ability to repair it.
Thanks for y'alls help,eh?
Brad
Old Jul 13, 2012 | 12:33 PM
mikeysfun's Avatar
mikeysfun
I had the same issue last summer, ended up having the entire system replaced under warranty. Dealer claimed system was compromised and full of grit and dirt. $1500 job and I paid $220 out of pocket.
Old Jul 13, 2012 | 12:39 PM
zhilton's Avatar
zhilton
I was wondering if the heat sink for the fan had gone out. On some vehicles, when it goes bad it will keep the A/c compressor from cycling...since the heat sink is usually in the blower box for cooling. I know in the past when it goes, regardless of make/model you loose the intermediate speeds and only have high/full speed and off.
But I think your on the right path, take it to someone that has all the tools/knowledge to handle a/c systems.
Old Jul 16, 2012 | 09:35 PM
draboo's Avatar
draboo
FYI on potential problem with AC hose
Brought truck in today for AC repair. Found out that the hose in the pic that runs beside the radiator(underneath the coolant filter) had a hole in it from rubbing against the radiator shroud. He hooked up the machine and found out real fast about the hole. He put a repair "link" on the hose that you can see in the pic, let the system "de-atmosphere" for 40 minutes, and recharged.
Wow! What a difference recharging makes! It gets cold FAST compared to before the hose repair.
total cost: $291
Coolness factor: priceless!
Check your hoses soon!
Uploaded with ImageShack.us
steve22chavez
Apr 30, 2018 02:39 PM
krisinwa
2004 - 2008 F150
20
Nov 8, 2015 01:11 PM
paulwjax
Jun 18, 2011 12:55 PM
primas75
Jun 30, 2008 08:03 PM
jameslaz
Jul 27, 2003 08:55 AM
