lowered and got a inch diffon the right side HELP?
Old Jul 11, 2012 | 04:02 PM
dunbar7x's Avatar
dunbar7x
ok so today i cut my coils, i cut one round on both left and right side i did one at a time not to get them switched up. good news is that the lower side is right where i want it bad news is left front is 1 inch higher how does that work? also instead of getting neg camber i got pos while doing this, what is going on? any help would be great.. thanks guys
Old Jul 11, 2012 | 04:23 PM
willowbilly3's Avatar
willowbilly3
Did you roll it out after you let it down? Just the way an I-beam swings, it won't find center until you roll the truck a ways.
Old Jul 11, 2012 | 07:04 PM
dunbar7x's Avatar
dunbar7x
Na I didnt I did jump up and down on it tho to try seating it
Old Jul 11, 2012 | 08:13 PM
HIO Silver's Avatar
HIO Silver
Follow willowbilly's advice and roll it about 10 feet forward and back to take the bind and scrub out of the suspension.
The original overall length of the spring may have had the same rate but lopping off a piece may have changed the effective spring rate over a shorter distance. Plus, it could be that the spring material that was cut off, metallurgically, had a different structure than the rest of the spring and took up more of the load.
Old Jul 12, 2012 | 08:44 PM
f100today's Avatar
f100today
Also ensure the spring is clocked correctly inside the perch.
Old Jul 12, 2012 | 09:32 PM
MIKES 68 F100's Avatar
MIKES 68 F100
+1 IF SPRING IS IN WRONG POSITION IT WILL BE HIGHER
PancakeF150
Aug 2, 2014 03:56 PM
Striker711
Jul 2, 2006 06:07 PM
r0n1n
Offroad & 4x4
Jan 16, 2006 03:34 PM
79beater
Dec 9, 2005 06:52 PM
