HELP removing HPOP
Old Jul 12, 2012 | 10:02 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here is the fix. You can do it preventatively or after the fact.
Riffraff Diesel: EZ-LOK HPOP Bolt Insert Kit
Old Jul 12, 2012 | 10:05 AM
mueckster's Avatar
mueckster
Originally Posted by timf150
So you over torqued the bolt?
I don't think I want to be in that position if I rebuild my HPOP. Hopefully the instructions give the torque specs and not leave it up to me to determine since I am not so good at "tightening by sense".
Tim M
Name:  HPOP torque.gif
Name:  HPOP Gear torque.gif
Old Jul 12, 2012 | 07:19 PM
fordtruck661's Avatar
fordtruck661
well after all that work I find that I still have a oil leak and I might have made it worse Im thinking that I did not clean enough between where the gasket is on the HPOP. all the fittings are dry and it seems to be coming from the bottom of the pump. Does that sound right? maybe some dirt is in between the seal.
lartross
Oct 9, 2014 07:24 PM
Jesser02EX
Sep 29, 2014 07:39 PM
Rojak
13
Aug 20, 2013 08:02 PM
GruesomeJeans
1978 - 1996 Big Bronco
May 4, 2012 12:05 AM
OZX1
Nov 11, 2008 08:27 AM
