Sponsored by: Real Truck
99 f250 AC problems!!!
Old Jul 11, 2012 | 11:58 AM
scottf250us's Avatar
scottf250us
Last week the ac in my truck stopped blowing on max. it blows fine on normal, but when i switch it to max it stops. the fan is still running but the air doesnt come out anywhere. Any ideas what it could be? 1999 F250
Old Jul 11, 2012 | 08:27 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
A cheap and easy possible fix would be to change your blower speed control resistor. If that doesn't get it try pushing and wiggling on the blower power connector. Have a helper tell you if the fan kicks on. I had a bad connection inside the blower recepticle and a new blower motor curred mine.
Old Jul 11, 2012 | 08:48 PM
projectSHO89's Avatar
projectSHO89
Only one thing changes between normal A/C and MAX (and it ain't the blower motor).
There is a vacuum operated door right up behind the glovebox that is supposed to switch position (open vent to interior) when the motor gets vacuum in MAX. The only thing that makes sense is that the cabin air inlet is blocked, perhaps by a plastic bag or something similar.
Old Jul 11, 2012 | 08:51 PM
BIG-DADDY-F350
I had a walmart sack sucked into my intake one time. It definatly restricted air flow
Old Jul 12, 2012 | 12:51 AM
Kajtek1's Avatar
Kajtek1
Turn the fan to high with engine off, open the hood and on passenger side of engine compartment under the gutter you will see blower housing with big plug going in. Push the plug in and try to move it a bit sideways.
Old Jul 12, 2012 | 06:12 AM
projectSHO89
He said "the fan is still running ".
It ain't a blower issue.... It's an airflow problem.
Old Jul 12, 2012 | 06:53 AM
scottf250us
thanks for the help. im going to check for restrictions today
Old Jul 12, 2012 | 10:51 PM
RPM371's Avatar
RPM371
Check the vacuum line that runs to the heater valve. Mine slipped off and the a/c would barely come out the vents on Max. I was sure I had a 4x4 leak and needed new seals. My mechanic fixed it in 20 seconds.
Old Jul 13, 2012 | 05:14 AM
scottf250us
it was a dollar general bag!
Old Jul 13, 2012 | 05:31 AM
projectSHO89
Knew it has to be something like that.
Wow, even with facts in front of them that disprove their ideas, the wrong answers just keep on coming!
jmuenchow
May 28, 2018 08:35 PM
Cyrusjohn
Dec 6, 2017 05:04 PM
lawdawg79
Jul 25, 2015 09:39 PM
dalkins1
Aug 24, 2007 01:51 PM
pcbman
Apr 25, 2007 01:08 AM
