Sponsored by: Auxito
Coolant Smell
Old Jul 11, 2012 | 10:34 AM
Truck55's Avatar
Truck55
Coolant Smell
I have an 01 supercab. 5.4 Triton 135k. I have begun to smell coolant the last couple of days. Have seen nothing leaking and truck doesn't run hot.
Will investigate more this weekend
Does anyone know where to start looking for this. It has to be leaking somewhere. Windows don't fog and the smell is there all the time. I live in florida so don't use much heat.
Not the heater core. Heat works fine and no smell from the vents.
Thanks in advance for any help on this problem.
Dan B
Old Jul 11, 2012 | 03:14 PM
dbreckman's Avatar
dbreckman
Ironically it is still probably in the heater core. wether using the heat or not the water/coolant still passes through on its way from the engine back to the radiator. catching the smell early with could be a good thing, buts its still a couple day job for the home mechanic. the whole dash must be removed.
Old Jul 12, 2012 | 02:32 PM
stevenn1's Avatar
stevenn1
Mine did same thing.
When on & warm can smell it with window/door open. When off can smell it at grill area. No drips, coolant level going down slowly. Replaced radiator ($150 Autozone, in stock). Problem solved. When warm & running i guess fan would blow smell towards cab area, when off smell would linger around front end.
Old Jul 13, 2012 | 08:47 AM
Truck55's Avatar
Truck55
Thanks much, you might be right. That is what mine does. with windows up and a/c on can't smell it inside.
I will check the radiator closely this weekend.
Dan B
Old Jul 14, 2012 | 07:06 PM
vista461's Avatar
vista461
I had a crack in intake in the coolant crossover where the aluminum meets the plastic. Nothing on the ground.
Old Jul 23, 2012 | 03:34 PM
Truck55's Avatar
Truck55
I am no fan of stop leak. But friend told me to try some. I did and no more smell or coolant loss.
I am sure it is a bandaid and I will have to do something else later on.
Dan B
Old Aug 8, 2012 | 08:03 AM
Doc's Avatar
Doc
My 97 F-150 developed the same exact smell yesterday. After reading a 20 page instruction sheet that somebody posted on the internet about how to remove the dash and heater core, I'm becoming a big fan of that Stop Leak stuff too. Good grief! Life is too short!
Old Aug 9, 2012 | 04:31 AM
BFTUFF's Avatar
BFTUFF
Could be a leak in a hose on top the intake manifold and is just evaporating, hence the smell. Also could be a slow leaking and evaporating HC leak It's time for the process of elimination to diagnose the problem.
Old Aug 9, 2012 | 07:02 AM
Truck55's Avatar
Truck55
So far stop leak has done the trick for me. No more smells and no lose of coolant.
Old Aug 9, 2012 | 02:59 PM
steve(ill)'s Avatar
steve(ill)
i dont know what your using, but i have had very good luck with BARS liquid copper. About $10 a bottle at Auto Zone. Suppose to plug small holes in head gasket, cracked heads and manifold leaks.. I had very good luck for 3-4 years now. I redo every 12 months.
Old Aug 25, 2012 | 01:00 PM
Truck55's Avatar
Truck55
well finally found my leak. it is the cossover pipe and is leaking on the passenger side.
So now I guess I have to replace the intake manifold.
what a stupid design.
Anyone ever replace the intake manifold?
Dan B
Old Aug 25, 2012 | 01:11 PM
vista461's Avatar
vista461
Yep. I put a new one on my 01 5.4 screw. Wasn't too bad to do.
Old Aug 25, 2012 | 05:32 PM
Truck55's Avatar
Truck55
have a pics or instructions on how you do it. I can do most anything but this looks like alot of work. If i can get some illustrations then maybe I won't waste so much time trying to figure it out
Dan B
zgiannijonesz
1997 - 2003 F150
Oct 30, 2007 08:43 PM
wickymustang
Sep 14, 2005 03:39 PM
fischbach
Dec 23, 2004 01:37 PM
wlihntr
Feb 14, 2004 05:06 PM
tediesel
Nov 20, 2003 09:54 AM
