No heat
Old Dec 20, 2004 | 07:00 PM
fischbach's Avatar
fischbach
No heat
I have a 1997 f150 that all of a sudden the heater is not blowing hot air when on. Now I've looked at coolant which incidentaly is a milky brown but oil level is fine. If one of you folks good give me a little guidance on where to proceed from here I'd be greatful. tks
Old Dec 20, 2004 | 08:42 PM
Steina's Avatar
Steina
CO River Rat
Are both heater core hoses hot to the touch? If only one is, your "milky brown" coolant may have plugged the core. If both are hot, you probably have a blend door problem.
Steve
Old Dec 21, 2004 | 03:15 AM
GermanGuy's Avatar
GermanGuy
The "milky brown" coolant may be a sign of a head gasket going bad, and exhaust gas passing into the cooling system. At idle you can remove the radiator cap and check for gas bubbles and exhaust smell. But be careful, the radiator may be under pressure, don't get burned by hot coolant!
LoL Dieter
Old Dec 21, 2004 | 04:45 AM
ford390gashog's Avatar
ford390gashog
have you ever serviced the coolant in this thing it sounds like a clogged heater core
Old Dec 21, 2004 | 12:25 PM
fischbach's Avatar
fischbach
First off tks. for replying. The answer is no I have not, I purchased truck approx. 4 yrs. ago and have never flushed radiator. truck has approx. 93k miles. The blower works, the fuses connected work. Is your suggestion to flush radiator and put in new coolant? Let me know, tks.
Old Dec 21, 2004 | 12:32 PM
fischbach's Avatar
fischbach
no heat
Steve
First off tks. for replying. If you could let me know where the heater core hoses are I will check. Tks.
Old Dec 21, 2004 | 12:40 PM
Steina's Avatar
Steina
CO River Rat
There are 2 small hoses running from the engine to the firewall on the passenger side; those are the heater core hoses.
Steve
Old Dec 21, 2004 | 03:27 PM
fischbach's Avatar
fischbach
Tks. again will take a look and get back.
Old Dec 23, 2004 | 01:37 PM
73Custom's Avatar
73Custom
The 'milky brown' coolant is shot and has to go, you need to flush the cooling system. Drain the antifreeze, then disconnect the hoses - upper and lower radiator and both heater hoses - and remove the thermostat. This is a good time to replace the thermostat and check the hoses for wear/firmness/cracks and replace if needed. I like to use a garden hose and flush the radiator from both directions, flush engine from both directions (where the radiator hoses were attached) and flush the heater core from both directions. Do this until you get clean water coming out the other side (be prepared for a big wet mess). Then reconnect hoses, install thermostat and fill with correct strength antifreeze. This may take care of the heat problem too... but needs to be done regardless.
Marty
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
russellkr
Nov 2, 2002 11:18 AM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
