Crossmember or Frame?
Old Jul 15, 2012 | 04:44 PM
4x484150's Avatar
4x484150
Thanks Franklin, that narrowed down my choices. But I was asking about the 2wd frames. From my research, I knew the 3/4 ton frames would be different, but it looked like the 2wd F250 i-beams mounted in the same spot as the 150's.
I also remember looking at trucks like yours, and seeing the front horns were the same, but I believe it was a 150.
Old Jul 28, 2012 | 10:28 PM
4x484150's Avatar
4x484150
So Ive been gone for two weeks, and Ive been looking around for frames, and they are all shot around here. I dont have the time or resources to go down south. What do you guys recommend? Wait for a good frame, or try to find a new crossmember?
Also, in the mean time, I need to figure out my front tank vs the back gas tank issue. The back tank is still hooked up, and works fine. Should I try to extend the filler hose up to the front gas fill door? Or is this unsafe? Thanks in advance.
Old Jul 28, 2012 | 10:38 PM
ctubutis's Avatar
ctubutis
Talk to BlueOvalDismantlers.
https://www.ford-trucks.com/forums/1...part-outs.html
Old Jul 28, 2012 | 10:43 PM
4x484150's Avatar
4x484150
Thanks Chris. I saw that thread the other day, but wasnt sure if they would be able to help. Ill check them out.
ericford1984
Oct 5, 2011 09:30 PM
smashclash
Jun 7, 2010 02:12 AM
dethomson
Maryland Chapter
Apr 3, 2009 04:33 PM
thepitshop
Jan 13, 2009 10:20 AM
fred_79f250
Aug 5, 2006 01:30 AM
