Looking for some helpful ideas
Old Oct 5, 2011 | 08:54 PM
ericford1984's Avatar
ericford1984
im resotring my 84 ford f250 and the frame is decent and the only problem i have is the crossmember that holds the side tank up. the angle pieces that go from the frame to the bottom of the xmember are rotted...anyone have any pictures of how they have fixed that....also the last frame x member that holds the rear tank..at the very end of the frame does anyone know were i can get one.. thanks!
Old Oct 5, 2011 | 09:22 PM
ctubutis's Avatar
ctubutis
I'm confused, I'm not aware of any crossmembers holding up gas tanks anywhere, only straps.
Can you post some pictures of what you're trying to describe?
Old Oct 5, 2011 | 09:30 PM
ericford1984
There is a crossmember that goes between the frame rails and over the side tank. Then the strap slides into a pocket on the cross member were it meets the frame then it bolts to the other side the crossmember
79str8six
Apr 14, 2011 04:57 PM
dethomson
Maryland Chapter
Apr 3, 2009 04:33 PM
thepitshop
Jan 13, 2009 10:20 AM
irondragon79
May 12, 2003 01:50 AM
