Torque Shift Trans Help
Old Aug 14, 2012 | 03:17 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by bismic
Everything points to the EBP sensor IMO.
Agreed. Also check the EBP sensor harness and clean the sensor tube while you're there.
Old Aug 14, 2012 | 10:34 AM
suzuki_vinson's Avatar
suzuki_vinson
Where is that sensor located?
Old Aug 14, 2012 | 11:22 AM
suzuki_vinson
Ok it sounds like you guys are right.. ive did alot of reading and many peeps had simular problems to what I am having.. where is the sensor located at and where is the best place online to order one from? Thanks so much for the info.. id be lost without this site!!
Old Aug 14, 2012 | 04:49 PM
npccpartsman
Depending on model year it's either attached to the thermostat housing or between cylinders 2 and 6 (drivers side). There's a steel tube that runs from the exhaust manifold to the sensor. Remove and check it for blockage also.
Old Aug 14, 2012 | 07:58 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I think he has the 06. See above post for the location between the #2 and #6 cylinders.
W7PSK
6.7L Power Stroke Diesel
18
Jul 25, 2018 08:41 AM
Santimanzano
Apr 4, 2017 10:50 AM
BigRed350
Feb 5, 2012 04:02 PM
SICKANDTWYSTED
Feb 26, 2008 08:44 PM
Alaska7.3
Aug 15, 2004 01:16 PM
