someone help please
Old Jul 5, 2012 | 04:45 PM
Superduty21's Avatar
Superduty21
someone help please
Just got my ficm back from ed after i was told that it was dead. Truck still wont start. No injector chatter at key on fmp drops off from 40 to 0 in about 3 sec
Old Jul 5, 2012 | 05:04 PM
metmop's Avatar
metmop
Ok. I am not a expert. What is battery voltage are the batteries due for replacement (if they are 10 years old they are due ). May want to pull them out and have auto zone and/or advance load test the batteries. They normally do it for free. From what I understand bad batteries and/or alternators can cause havok to FiCM. I was having this problem with intermittant long starts and no starts.... replaced the batteries and GTG.
Old Jul 5, 2012 | 05:05 PM
BLADE35's Avatar
BLADE35
Have you checked the FICM Relay???
What are you getting for FICM Lodgic Power and FICM Vehicle Power
Great Idea to check Battery and alternator as mention above
Old Jul 5, 2012 | 05:10 PM
Superduty21
Wat relay is it? Ill just buy a new one. 12.49 volts at the batterys. Im ready to torch the truck and buy a 12v. Fvp on my scangauge is 12volts
Old Jul 5, 2012 | 05:22 PM
BLADE35's Avatar
BLADE35
Whats this FLP
FLP FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 0064010000000 NAM: FLP
FVP 07E02209CE 0462450906CE 3010 006401000000 name FICMVehicle Power
If you get 12 or so volts for FICM Vehicle Power and 12 or so For FICM Lodgic Power then the relay is Good Watch it for a few make shure you dont loose Power to either when FMP dumps all Power
If you Loose FICM Lodgic Power or FICM Vehicle Power then might be a relay issue check them out lets see what happens
Was your 12.49volts at batterys with truck off Im shure since wont start
All Battery cables including grounds Clean good connections???
Old Jul 5, 2012 | 05:23 PM
BLADE35's Avatar
BLADE35
What does Volts drop to on SGII During cranking????
Old Jul 5, 2012 | 05:24 PM
Superduty21
The fvp wont come up on my scangauge. Thats the voltage at the batterys with it on jumper cables. Im gonna have the batterys tested now. What number relay is it? Where is it located?
Superduty21
Stayed at 40 but one time dropped to 0
Old Jul 5, 2012 | 05:40 PM
BLADE35's Avatar
BLADE35
Sounds like bad batterys and or alternator
Better check them Both
theres a Black box right there with a relay and fuse for the FICM
Theres some info in tech folder under ficm it will give you spcific
Old Jul 5, 2012 | 05:44 PM
BLADE35's Avatar
BLADE35
the FICM Gound is Bolted to the Intake stud right???
check that but sounds like charging system issue
Old Jul 5, 2012 | 05:46 PM
Superduty21
Yes the ground is. The battery are looking like there ****
Old Jul 5, 2012 | 05:47 PM
Superduty21
If i run a ground from the ficm ground to the battery ground will it hurt?
Old Jul 5, 2012 | 06:53 PM
Superduty21
Betterys did nothing
Old Jul 5, 2012 | 07:33 PM
BLADE35's Avatar
BLADE35
Did the Batterys Load test Bad???
How about the alternator did you get it tested????
As long as the FICM ground is bolted to the back stud running another wire wont help and its good
Old Jul 5, 2012 | 07:34 PM
Superduty21
They tested like ****. Found a bad relay. The alternator is maybe a month old
