73 c6 bolt
Old Jul 9, 2012 | 10:29 AM
Radster's Avatar
Radster
73 c6 bolt
I am looking for the teflon sleeves that fit over the bolt that attaches the shifter to the transmission. Anyone know where to find them? I looked at Broncograveyard, Dennis Carpernter, and LMC with no luck. Thanks
Old Jul 9, 2012 | 12:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Not exactly sure what you mean by "teflon sleeves".
Look at the illustration from the Ford master parts catalog.
Let me know what part you're reffering to and I'll see if I can locate it.
Click on the .pdf link and scroll to bottom half of page.
File Type: pdf
Old Jul 9, 2012 | 12:31 PM
fellro86's Avatar
fellro86
I believe he means actually the seal in the transmission case where the shifter arm goes through into the transmission.
Old Jul 9, 2012 | 12:40 PM
Papa Tiger's Avatar
Papa Tiger
Do you have a trans leak at that area, a seal leak coming from the shaft where it enters the trany ?
Old Jul 9, 2012 | 01:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If the OP is talking about the shaft seals (see basic p/n's 7B498 and 386078-S in illustration below).
D5AZ-7B498-A
Oil seal, manual control lever
3/4" ID X 1 11/16" OD X 7/32" Thick
386078-S
Seal, throttle control to outer shaft
3/8" ID X 5/32" OD X 3/32" Thick
There are a bunch available. Many, many dealers and obsolete suppliers have them.
The 386078-S is just a standard O-ring and just about any hardware store would have one, the seal can probably be bought at any bearing supply house.
Green Sales, Cincinnati, OH has 56 Seals and 319 O-rings (800) 543-4959
Manderbach Ford, Temple, PA has 11 seals and 46 O-rings (610) 929-3683
Dobbs Ford, Memphis, TN has 3 seals and 12 O-rings (866) 219-5755
Midway Ford, Hurricane, WV has 2 seals and 8 O-rings (304) 562-3315
File Type: pdf
Old Jul 9, 2012 | 01:50 PM
Radster's Avatar
Radster
tranny bolt
After looking at it again it hooks up to the 4 wheel drive shifter. It is approximatly 3/4 inch bolt that is a pivot point for the arm to the transfer case. It currently has 2 telfon sleeves around it, but maybe it is a modification made by someone else? Sorry for the confusion and thanks for the answers.
FLgargoyle
Aug 18, 2023 01:02 AM
FDMS67
May 25, 2011 02:07 PM
DKW 86
Sep 7, 2010 10:14 PM
rmalottwtes30
Apr 16, 2008 08:46 AM
fomoco3904
Mar 10, 2005 11:32 PM
