C6 Leak question...
Old Sep 5, 2010 | 07:45 AM
DKW 86's Avatar
DKW 86
C6 Leak question...
While working under the truck eliminating a leak, i find an apparent leak from something i have no experience working on.
As you look at the tailshaft of the C6, there is a bolt, about 5/8 or maybe 11/16, just to the right of the tailshaft. The bolt is pointing toward the front of the truck. The bolt on my truck is obviously new/been replaced. It looks like SS and is shiny as can be, it also has no washer facing on the underside like every other bolt on the C6. That is apparently where my leak is coming from.
Can i R&R this bolt and not screw up my transmission? Is this factory or i am just wrong? Is there a seal there or do i just need the correct bolt there?
Look, been around most engine, electrical, fuel, body issues etc. But i dont now beans about no transmissions. Might as well be voodoo to me.
Please help a bro out here!
Old Sep 5, 2010 | 09:52 AM
79 f350ts's Avatar
79 f350ts
just went out to look at my c6, not hard as its out of the truck. saw nothing as you described, maybe a picture would help?
Old Sep 5, 2010 | 10:07 AM
RangerHaywood's Avatar
RangerHaywood
Is this a 4x4 truck or not?
Old Sep 5, 2010 | 10:11 AM
79 f350ts's Avatar
79 f350ts
his sig says AWD, so im assuming 4x4?
Old Sep 5, 2010 | 10:20 AM
RangerHaywood
If hes referring to it as being AWD then im going to assume he has a NP203 Full-Time T-Case...
Old Sep 5, 2010 | 10:30 AM
79 f350ts's Avatar
79 f350ts
that would also explain why i see no such bolt in mine, its a 2wd. Dont know much about 4x4 myself, maybe you can help him from here?
Old Sep 5, 2010 | 03:06 PM
RangerHaywood
Haha then that might be why...do you have a pic that we can see so we know where your lookin?
Old Sep 5, 2010 | 03:16 PM
DKW 86's Avatar
DKW 86
Soon, but not now, sorry guys will work on a pic.
Old Sep 5, 2010 | 10:49 PM
DKW 86's Avatar
DKW 86
Post
Didnt get a pic. Found a pic tho. Thats the bolt i was talking about just above the modulator valve. Couldnt even see the valve because of a brace. Evidently my leaking bolt problem is with the tailshaft retaining bolts. i can take them out and replace them with no problems right? But to solve the leak, i may have to replace the gasket there too. Can i just take the yoke off and R&R the tailshaft?
Old Sep 6, 2010 | 06:16 PM
RangerHaywood
I believe your theory to be correct
Old Sep 7, 2010 | 07:50 PM
79 f350ts's Avatar
79 f350ts
i too believe that to be correct
Old Sep 7, 2010 | 10:14 PM
DKW 86's Avatar
DKW 86
Thanks, it is on the to be done list now.
JTPass
Nov 15, 2014 05:42 PM
maxum96
Jul 2, 2014 03:50 PM
markkay4356
1978 - 1996 Big Bronco
Nov 20, 2013 09:33 PM
markkay4356
Nov 20, 2013 12:56 PM
