C6 Transmission question
Old Mar 13, 2011 | 09:08 PM
FDMS67's Avatar
FDMS67
Angry C6 Transmission question
I have a leak from my shifter bushing or seal. I guess I should ask is it
concidered a bushing or seal? Can it be removed and replaced without
needing in special tools? I know I need to drop the pan and remove the
valve body, that's not a problem. Can I get the shaft out easy enough
to replace the leaking part?
Old Mar 14, 2011 | 09:41 AM
Mike G's Avatar
Mike G
It's been a while since I did a rebuild, but I want to say that you can even probably do this without dropping the VB.... I think it is a seal, you should also be able to find a C6 schematic online someplace.
--Mike
Old Mar 14, 2011 | 11:56 AM
Jigger2020's Avatar
Jigger2020
Yes its easy to do & probably lower the VB because you have to take the kick down lever
out from inside, there is a lip seal in the case & an o-ring on the small shaft.
When you loosen the 1/2 '' nut hold the lever so you dont bend the inside part.
Dont over tighten the nuts, they will break or strip.
Check the screen while you are in there
Old Mar 14, 2011 | 07:50 PM
FDMS67's Avatar
FDMS67
Thumbs up
Thanks for the feedback guys. Sounds like this is something I can handle
then as long as I can locate a replacement part without having to purchase a whole transmission kit. Off hunting!
Old Mar 14, 2011 | 08:01 PM
Jigger2020's Avatar
Jigger2020
Go to any tranny shop & they always have extra seals around.
Should be 2 or 3 bucks unless they are gready.
Old Mar 15, 2011 | 09:57 PM
FDMS67's Avatar
FDMS67
Thanks Gigger, I had the same thought about a transmission shop until I
just happen to find one listed at Oreilly's for $7.49. Guess I will find out
who's cheaper.
Old Mar 19, 2011 | 11:28 PM
PiNkPaNtHeR58's Avatar
PiNkPaNtHeR58
All this being said, does anyone know what a total rebuild of a C-6 for my 1969 F-100 should run? I have been reading about new Kevlar belts and other cool stuff. I am just beginning to plan my restomod and will have a totally new engine. I'd like to hook her up with a better than new tranny. I've been saving my pennies for months now. I hope I can afford this.
Old Mar 20, 2011 | 08:36 AM
Jigger2020's Avatar
Jigger2020
Hey Pink, if you shop around you can get a C6 built for around $800 to $1000. then more depending what all you want in there. New torque and HD band & clutches & shift kit..........
Old Mar 20, 2011 | 12:41 PM
PiNkPaNtHeR58
Thanks Gigger. I'm just starting to plug some numbers into my resto plan. Man, it adds up fast. I'm already approaching the 20K mark. Still, it'll be better than financing a new one.
Old May 24, 2011 | 11:53 PM
Lvcrprts's Avatar
Lvcrprts
Well Pink this way by the time your done you will have a truck exactly the way you want it and not have to have a degree in order to work on it. I am a huge fan of keeping the older trucks on the road spanking a rice burner when one trys to act tough. I cringe a little when i fill up but i also know that if something goes wrong, i can either order the parts or ask on here and get all the info i need.
Old May 25, 2011 | 12:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FDMS67
As long as I can locate a replacement part without having to purchase a whole transmission kit.
D5AZ-7B498-A (replaced C7AZ-7B498-A & C1VP-7B498-A) .. Seal-Manual Control Selector Lever / Available from Ford.
MSRP: $3.66 // FTE sponsor PARTSGUYED.COM price: $2.64.
Applications: 1961/67 FX C-O-M / 1961/72 MX C-O-M / 1969/85 FMX C-O-M / 1964/81 C4 / 1966/97 C6 and A4LD, AOD, E4OD and et cetera, et cetera, et cetera!
Old May 25, 2011 | 02:07 PM
qman's Avatar
qman
The guy at Autozone called it a shift shaft seal and it was only a couple bucks and yes, it's easy to replace.
53fatfndr
Sep 8, 2021 10:27 AM
beartracks
Apr 18, 2016 01:54 PM
NotSoSporty98
Nov 27, 2015 03:04 PM
eyewall
Oct 24, 2015 07:01 PM
Jay_ford476
1997 - 2003 F150
May 25, 2013 07:56 PM
