Code questions
Old Jul 7, 2012 | 07:51 AM
jchamb11's Avatar
jchamb11
Code questions
It starts like this. My 2003 F350 , 7.3 shows an intermittent check engine light. The local dealer ship wants 189.00 to run diagnostics. The local parts store did it for free. The warning light was not on at that time and it threw no codes. The question is, If I turn the key to the on position three times will it go to self diagnostic mode and show codes in the lcd odometer readout? The last question . I would like to find the chart that describes the code and fix.
Thanks guys , Jerry
Old Jul 7, 2012 | 07:58 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This should help you with the codes. Welcome to guzzle's Diagnostic Trouble Code list Web Page
The parts stores can't read the codes on our truck. Good luck.
What kind of problems are you having???
Old Jul 7, 2012 | 08:27 AM
jchamb11's Avatar
jchamb11
Thank you Sir, I'll save the link. There was a drop in mileage when summer blend came in but other than that and a slight front end shimmy, she is fine. Had the injector cups replaced last spring, starter , and batteries. I consider that maintenance.
02exploderxlt
May 3, 2007 09:56 PM
pup55
1978 - 1996 Big Bronco
Jan 14, 2006 06:32 PM
sadrok
1983 - 2012 Ranger & B-Series
Jun 7, 2005 08:40 AM
Pikachu
Florida Chapter
Jul 12, 2004 10:23 PM
mcastleberg
Aug 13, 2003 11:11 AM
