Vacuum Leak
Old Jul 21, 2012 | 06:21 PM
hammer65's Avatar
hammer65
Well I'm still at it. Pulled a vacuum on all the lines (I THINK) that goes to the hubs.
I then removed the line at the switch, and pumped 15" into the line.
It held just fine. I pulled 10" at each hub port, no leaks.
I now believe it might be the vacuum switch, because when I turn the hubs on ,the vacuum dumps immediately somewhere.
Old Jul 22, 2012 | 05:44 AM
Tugly's Avatar
Tugly
That was the very first part that failed after I aquired "Stinky". I had to get mine at the dealership, but you might find one online. I called it the ESOF module, but the wiring diagram calls it a "Vacuum Hublock Solenoid".
Old Jul 22, 2012 | 05:52 AM
hammer65's Avatar
hammer65
Thanks Tugly: I just can't think now that it is anything else. Maybe if I hook my hand pump up to the switch,and turn it on, it might show up for sure.
I might get my wife to assist and try that. Thanks Jim
Old Jul 24, 2012 | 12:44 PM
hammer65's Avatar
hammer65
At how many inches of vacuum,should the pump kick off.
I am kicking off @ 16" and restarting @ about 13 "
Does this sound correct?
I have a very slow leak in the RH Hub. 1" in about 5 seconds.
I am still searching for answers.
Old Jul 24, 2012 | 10:40 PM
Tugly's Avatar
Tugly
I didn't measure mine, but that sounds good.
Old Jul 25, 2012 | 05:50 AM
hammer65's Avatar
hammer65
Thanks Tugly: I think I have about solved it. I still have a slow leak in the right hub.
I have replaced the outside seal, but have not changed the yellow seal yet. I replaced everything about 18 mo's ago, when I did the ball joints.
Oh well, if it wasn't for these little problems I might be bored. Thanks Jim
Beaglebus
Feb 17, 2015 09:42 AM
huntke
Jan 3, 2014 06:09 PM
PAf250
Feb 23, 2012 12:33 PM
Loopy
Aug 11, 2010 10:53 PM
PublicNuisance
Aug 5, 2010 09:15 AM
