Front hub problem
Old Feb 13, 2015 | 01:13 PM
Beaglebus's Avatar
Beaglebus
Front hub problem
I have a drag/click coming from my front wheel. I had thecaliper off so it was definitely in the hub assembly. I went ahead and greasedthe hub through the ABS sensor but the drag/click was still there. I amthinking it is either the wheel bearing or the axle bearing. My question is ifI lock the hub and the drag/click goes away does that mean it is the axlebearing? Also, is it possible the auto locking hub could be part of the problem?<o></o>
<o></o>
By the way, my Ex has 130K on it and the 4x4 auto selectworks fine. There is no play in the hub and no noise that I can hear. The onlyreason I am digging into this is a drop in gas mileage that led me to find outthat both front wheels are very tough to rotate (with the front drive disengaged).<o></o>
<o></o>
Thanks in advance<o></o>
Old Feb 13, 2015 | 07:17 PM
Lance Helmert's Avatar
Lance Helmert
So when you lock the hubs, the wheels turn easier? I would remove the hubs and inpect for broken parts.
Old Feb 14, 2015 | 07:08 AM
05MilMachine's Avatar
05MilMachine
My esof hubs recently failed to disengage properly. Even manually they would stay partially engaged enough to click and or turn the axle. I have a set of mile markers in the garage waiting on me. Also, there are bearings in these locking hubs that get noisy even on a functioning hub. Mine have been clicking for about a year now at low speeds.
Old Feb 14, 2015 | 07:28 AM
howler4x4's Avatar
howler4x4
Yeah, it's pretty easy to remove the locking hubs as a diagnostic step. Spin the wheel before & after. You can also examine the hub to see if it's locked, open or partially engaged.
I'd recommend examining the axle u-joints while spinning before taking anything apart.
Old Feb 17, 2015 | 09:42 AM
Beaglebus's Avatar
Beaglebus
Its the hub ...
I was able to lock the hub this weekend and the "click" went away,but turning it was not substantially easier. I went ahead and ordered theseal/retaining clip set from DieselOrings.com and plan on cleaning/lubing thehubs next weekend.<o></o>
7622RM
1983 - 2012 Ranger & B-Series
18
Mar 22, 2019 10:25 PM
abslayer
6.7L Power Stroke Diesel
22
Nov 13, 2012 11:14 PM
jeff2011
Sep 7, 2009 10:54 PM
rong63
Feb 23, 2006 10:56 AM
Dakrri
Nov 11, 2004 11:55 AM
