E350 No start...
Old Jul 7, 2012 | 03:13 PM
drs041's Avatar
drs041
I have the same x code entered, just verified it.
Still coming up 0
Any idea where exactly the trans pos sensor is?
It looks like it might be on top of the trans,but im not sure, looking for it now.
Old Jul 7, 2012 | 03:23 PM
BLADE35's Avatar
BLADE35
here like 3-4-5 pages down
http://api.viglink.com/api/click?for...13416925119783
Check all wireing to it too
Old Jul 7, 2012 | 03:33 PM
drs041's Avatar
drs041
looks like i will be doing a trans fluid and filter change as well lol.
Old Jul 7, 2012 | 04:42 PM
BLADE35's Avatar
BLADE35
what does SGII show for V-Ref hopefulley 5 volts
Old Jul 10, 2012 | 11:39 AM
drs041's Avatar
drs041
V-REF shows 5 volts
The transmission range sensor should be here today, hopefully i can get it started and diagnose the stalling issue.
I found an oil leak underneath, looks to be the rear main seal but i have heard that it might be something else, maybe an O-ring somewhere further up top?
Old Jul 12, 2012 | 06:46 PM
drs041's Avatar
drs041
Anyone pull the transmission range sensor without disassembling the entire transmission before. Im trying to get at it now and i can't seem to get it out....
EDIT:
Figured it out, looks like i need to buy special tool 211-S060, roll pin set. I don't suppose anyone has one to sell me cheaper than I'm finding online...
EDIT#2
Check that, looks like its just a punch set, I'll figure it out.
Old Jul 12, 2012 | 08:54 PM
BLADE35's Avatar
BLADE35
I never took the TR sensor out
Let us know how it goes
Old Jul 12, 2012 | 08:56 PM
cheezit's Avatar
cheezit
a roll pin punch is not the same as normal punch.
and replacing a tr sensor sucks. maybe mark knows a short cut.
Old Jul 12, 2012 | 09:50 PM
m-chan68's Avatar
m-chan68
Don't ask me why, but I have this awful feeling that replacing the TR sensor is not going to fix your no-start issue.
Old Jul 12, 2012 | 09:58 PM
drs041's Avatar
drs041
The tr sensor is out according to the scan gauge, it went out while trying to restart the truck from the stalling issue that I believe is from somewhere in the hpop assembly. I'll be tearing into the stalling tomorrow.
I'm pretty sure the no start is from the tr sensor because all the tail lights work with the car in the on position except the reverse lights. Also the reverse beep is not working anymore and all of this was when the truck was stalling before the sensor took a dump.
Old Jul 12, 2012 | 10:02 PM
m-chan68's Avatar
m-chan68
Did you verify your transmission harness wiring is properly connected in all places, particularly the PCM and the one at the back of the transmission with the "dog house" removed?
Old Jul 12, 2012 | 10:04 PM
drs041's Avatar
drs041
Unfortunately, yes...
Old Jul 24, 2012 | 04:13 PM
  #28
drs041's Avatar
drs041
Did a ton of reading, went out to the van, disconnected the fan clutch and it fired right up. Going to top off the trans fluid and I'm going to fix the stalling issue.
Old Jul 24, 2012 | 06:43 PM
  #29
BLADE35's Avatar
BLADE35
Cool you found it
The normal is the Wireing to the fan clutch chaffes and wont start IIRC
Old Jul 24, 2012 | 06:44 PM
  #30
cheezit's Avatar
cheezit
once again pull the fuse that controlls the fan clutch make sure its good. ona truck its f2-22 a van my be different
RenoHuskerDu
Jun 6, 2018 05:32 PM
RenoHuskerDu
Modular V10 (6.8l)
Jun 1, 2018 07:12 AM
Kendrick
Aug 9, 2010 08:21 AM
smayjr
Mar 16, 2006 10:50 AM
geson
Jul 15, 2004 12:52 PM
