Sponsored by: Auxito
first post.
Old Jul 4, 2012 | 10:00 PM
marshallford's Avatar
marshallford
first post.
Like to start off by saying go FORD!!
ive loved fords forever!!!
Ive just got my first truck 2003 xlt 2wd 4.2l v6 5speed(learned at an early age) plane jane but i love it!!!! im very lucky!!!
we own three fords.
a 1999 f150 4.2 wid 210,000miles
a 2003 4.2 with 103,000miles
and a monster 198?s f350 that is our plow truck with a 350 v8. i personaly used this truck to pull down a dead tree lol (needed fire wood)
but back on topic im trying to get more power out of this 4.2 its just so sluggish. im planing on a K&N intake system. how much horse power will that give it? and how does a thrush glass pack sound on the v6?
Thanks Marshall
Old Jul 4, 2012 | 11:32 PM
Bluegrass 7's Avatar
Bluegrass 7
I understand your enthiasium but there is no power in filters or changes and a muffler change won't help anything but change the sound.
Go with a little science and common sense.
The stock filter passes more air than the motor can use so a replacment won't add anymore the motor can use.
Same with the exhaust system.
The motor displacment is quite small and uses all the same filter capacity and exhaust capacity the bigger motors use.
In this day and age the factory cannot afford to let any power lay in small parts due to competition with other makes for sales.
The application is 'truck' not prerformance.
You may be trying to compare with a 350 cu/in Chev that is no match to the small v6.
As you might have noticed, the new v6 is outfitted with a turbo charger to get the power of a bigger motor and does infact make more torque down low than an NA motor of larger size.
Hope I have brought some perspective to you about the situation.
Good luck.
Old Jul 5, 2012 | 10:38 AM
marshallford
not trying to compare to the v8. just want little more power. thought a cold air intake would help
Old Jul 6, 2012 | 05:46 PM
steve(ill)'s Avatar
steve(ill)
No, it will not help. Bluegrass is spot on.
bclay1983
1997 - 2003 F150
Jul 6, 2014 12:35 PM
newyorkredneck
3.8 & 4.2L V6
Sep 10, 2008 05:04 PM
johnbehrhart
1997 - 2003 F150
Dec 16, 2006 01:15 AM
MickDempsey
1997 - 2003 F150
May 26, 2004 04:48 PM
kman2785
1997 - 2003 F150
Aug 25, 2003 12:24 AM
