Smacked it and it works! but why?
95 F350 351 with EO4D........I was driving down the road and noticed the speedometer wasn't working and the odometer was blank. All the other gauges were working fine. I smacked the instrument cluster lightly one time (I don't know why, just a habit from growing up with old CRT TV's) and both have worked fine since. The truck has never done this before and it was working when I started up the truck. I searched the forum and this seems to be a common complaint.......but if it were the common issues of the VSS or PSOM why would smacking the cluster fix it ( at least for now )? Thanks guys.
on
95+ PSOM bad solder joint.
here's how to fix:
https://www.ford-trucks.com/forums/7...ml#post6612972
here's how to remove,repair step by step,and replace:
PSOM replacement/repair in 1995 Ford F150 trucks
you described the symptom perfectly.that sure was nice.saves a lot of time trying to help someone.thanks!
often people leave out stuff and leave ya guessing,and then latter on they're oh yeah and i did this,or this happened.....
here's how to fix:
Authenticraft
19
04-19-2024 08:53 PM
Punisher95
04-08-2008 03:12 PM
