Not sure if this should go in here or the F250/F350 forum but since it is a 6.0L PSD I am going with here (besides I like you guys!!! )
I have a 2004 F350 FX4 SRW offroad with 8 foot bed. It just had the 135.000 mile service done (sorta). As part of the 150,000 mile service the rear axle fluid is supposed to be changed. The cover of the differential is oxidized and very flaky. I plan on replacing it as part of the 150k service. I couldn't find a part number for it from FORD or a cost....
I went to Auto zone and for $40 I can get a chrome plated steel. For $150 I can get polished aluminum cover. Online for about $260 I can get a Mag hytec aluminum cover with powder coating and extra capacity and or Afe Power cover that is similar.... I am sure there is others..... lots of others.... just curious if the oversize it worth it.... and if steel or aluminum is better Just wanted everyone's take on it?
Do you tow or offroad much? If not, look at the 2009/10 F250 stock cover. Pretty much the same thing except aluminized. Get it from one one the Ford Parts sponsors here on FTE.
The 2008/09/10 F250 rear covers are not aluminized, there finned cast aluminum covers.
I just bought the truck 2 months ago. I plan on towing. I have 2 motorcycles I want to transport around. While I would prefer to ride them to events carpal tunnel in both hands makes it difficult. As far as offroad not really.
I opted to clean and repaint mine. The rust and flaking appeared pretty bad but once I got the cover off I saw there was plenty of good metal in the cover.
I did mine back in Oct 2011 and the paint still looks fine.
Spend 80.00 and get the cover from a 2008-2010 PSD, I did and am happy with it. They are aluminum with fins for cooling and they look awesome. Just remember you should probably think about getting new bolts for it as well....you can pick these up anywhere.
Also....don't forget to put in SYNTHETIC oil with the additive already in it or buy the additive for it, if not you will ruin your clutches back there.
IMO an expensive cover with an extra quart of fluid capacity isn't worth it....now if you're talking trans pans then yes.
IMHO mag hytec is the bomb! In addition to the added fluid capacity, you can add a temp probe, it has a dipstick to check wear and fluid level, it has an inspection plug for correct filling, and most importantly a drain at the bottom to change fluid without removing the cover. Oh and gasket cement is not required to seal the cover as it has an o-ring seal. And it looks
As others have said, go with the oem cover for '08+ diesel trucks. It is a cast, finned aluminum cover and a great value. You will need longer bolts to go along with it.
I was in the market years ago for a mag hytec until i found out the extra capacity, finned casting, overly priced cover with a temp probe only lowered temps by a measly 6*F-8*F. Luckily I read a post here before I wasted my money.....just my opinion.
Thanks for mentioning the longer bolts cartmanea.....I knew i changed them for a reason.....just forgot why
I stand corrected.....
If I were towing (I am), I would opt for the Mag-HiTec (or however it's spelled) as I want to put in a temp probe. But I tow much heaver than you. I'll replace my stock cover when it comes time to change the fluid.
I just changed both of my diffs last weekend and I am with Piolet, the guage of covers are heavy. I was surprised how rusty it was and how the paint was flaking.
I sandblasted them and primed and painted. The $40 chrome covers will get paint sooner than you think because of rusting imo.
This is a really good idea and it looks like it turned out very nice.
Sounds like a plan. I think I will pull the cover as part of the maintenance and then decide. I can either sand and spray or replace. Just out of the curiosity does the 08 OEM cover have a drain plug in it. The $150 dollar aluminum one from auto zone does.... not sure if that is worth the $70 dollars extra but that is another issue altogether
No it does not have a drain plug....but in all seriousness, at the drain interval you want to remove the cover and clean all the collection of stuff on the magnet and clean the inside of the diff.....draining the diff and not removing the cover is not the right way to do it...IMO
The DANA covers are super thick and reliable, but not the best for cooling. If you are going to beat the $h*t out of the truck and possibly jam the diff into rocks, the stocker is the ONLY way to go.
I agree with you the cover should be pulled..... I like drain plugs for several reasons... mostly dealing with hot oil and less mess Not sure if you ever done a oil change and the oil you thought was cool was still boiling.... you get the idea... Course that is normally my wife's fault. You either have to hold a gun to her head or schedule a appointment to work on her van Anyways I like drain plugs to control the oil flow before removing the cover.... and it gives me something else to curse at and strip out
Here is the cover I was talking about that auto zone had for $150
