Missing while cruising
Old Jul 2, 2012 | 06:36 PM
Redsand187's Avatar
Redsand187
1995 5.0l F150. The truck seems to run fine when you start it up. Get it up to operating temp and start cruising with a light load and it will begin missing/bucking. Tap the throttle a bit, and it runs normal. WOT no problem.
Plugs, wire, cap, rotor are all relatively new. ~120K miles, the truck is pretty much in retirement. Only gets used for dump runs, hauling, and if it snows. However, the gas is fresh and even upped it to premium on the last tank with no real difference.
Any ideas for something common to look for? I'm wondering if it might be the pickup coil.
No, CEL or codes. TPS wires were bare and appeared to be shorting on a hose clamp, so TPS was replaced, made no difference
Old Jul 3, 2012 | 02:06 PM
oldfordcoupe's Avatar
oldfordcoupe
sounds like a vacume leak look real hard in all places ??
Old Jul 4, 2012 | 07:11 AM
Conanski's Avatar
Conanski
You could have a leak in the smog system, I had an '89 that developed the same symptoms and turns out the air pipe connecting the heads at the back was cracked and that caused the motor to run excessively lean and stumble particularly bad at highway cruising speeds.
zottyzot
Sep 8, 2011 07:53 AM
89 superduty
May 10, 2011 08:53 PM
KW160
Dec 11, 2008 11:52 AM
ajm859830
1997 - 2003 F150
Oct 13, 2006 09:03 PM
dongreene
21
Jul 6, 2006 10:45 PM
