Sponsored by: Real Truck
power/shift problem
Old Jul 1, 2012 | 04:42 PM
maxuk's Avatar
maxuk
power/shift problem
Hi Guys,
i have a problem when asking for maximum power. When i floor the accelerator to overtake the kick down works the revs go to 3000 it wont change up and i can hear a whistling like a air release. if you back the revs of it will change up but if you push again it does the same as the revs get high.
i have reved it flat out whilst under the hood and cannot hear the whistling so i guess all turbo pipes are ok.
Its 7.2 l diesel with a auto box, its a bit tricky when in traffic at about 70 when you want to overtake!
Any help gratefully received over here!
Cheers Max
Old Jul 1, 2012 | 05:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think the problem is that the engine has a problem reaching higher RPMs. Fix the engine problem and the trans will be fine.
Sinister7_3
Mar 6, 2016 03:44 AM
Saddle1up
Aug 7, 2014 06:43 PM
SilverBullet131313
Nov 26, 2006 03:04 PM
mybigredford
Nov 10, 2004 11:53 PM
sugarloafer 313
Jun 2, 2004 03:06 PM
