now im clueless
Old Jul 1, 2012 | 02:29 PM
musclecars90's Avatar
musclecars90
now im clueless
Well back in about march/april. Studded and deleted my truck with a new oil cooler. and everything was working great. Now about the past week to two weeks the tea kettle whistle is back, but now its worse than it was before. The truck can be sitting there idling and just a constant whistle then pause for a few seconds then come back and its louder then last time before the heads. Is it possible for the cap to that bad where its not holding any type of pressure. Any help would be appreciated.
Old Jul 1, 2012 | 02:54 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes, it IS possible..... do you know that the whistle is coming from the degas bottle? The bottles have been known to leak at the seam.
Old Jul 1, 2012 | 03:00 PM
musclecars90
im pretty sure not 100% positive though
Old Jul 1, 2012 | 03:02 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and the caps have also been know to leak. Did you replace yours back when you did all the other work? Cheap enough to replace.
Old Jul 1, 2012 | 03:06 PM
musclecars90
no i didnt, it was down for about two-three weeks because we ran into other problem, a bolt broke off in the front cover so I needed to get another one, leak in the radiator so had to wait for them to come in and just wanted it back on the road and didnt even think about replacing the cap or the bottle.
Old Jul 1, 2012 | 03:13 PM
BLADE35's Avatar
BLADE35
Bud is Dead ON the MONEY thats what I would try at this point to
but let me ask about the work more
OEM HeadGaskets?????
Did the heads get Decked or cut??? checked for warpag
was this a 1 stud at a time deal
Check the CAC Boots clamps to they also can whistle if loose
Old Jul 1, 2012 | 03:19 PM
musclecars90
about the work.
black onyx head gasket
arp's torqued to 225 when they said 210
I did have the heads checked for warpag and they came back as good.
The only side that had the blown gasket was the driver side. And ill check the CAC boots.
Old Jul 1, 2012 | 03:22 PM
musclecars90
forgot one more thing sometimes it will push coolant out other times it wont. thats why Im leaning more towards the cap being bad or the the actual degas bottle. When i do put coolant in its not that much I have to top off. Where when I had the blown head and EGR and clogged oil cooler I was putting about a gallon a day in.
Old Jul 1, 2012 | 04:52 PM
Roasted7's Avatar
Roasted7
Uh oh!
brettdacosta
Nov 19, 2012 10:27 AM
CobraBern
Dec 17, 2010 07:39 PM
jmarblack
Mar 30, 2010 09:01 AM
jho410
Oct 21, 2005 09:36 AM
1977rangerxlt
Sep 11, 2002 03:20 PM
