O2 Sensor Change Out Questions
Old Jul 1, 2012 | 01:03 PM
38-72's Avatar
38-72
I'm going to change my O2 sensor in my ’97 F250 (7.5/460). I can only find one. Is there more than one? Should I wrench it out with the exhaust hot or cold? Would penetrating ing oil help?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jul 1, 2012 | 02:17 PM
Conanski's Avatar
Conanski
There is only one sensor and if it's been in there a long time it wouldn't be a bad idea to get some heat into the pipe beforehand. Also use a boxend wrench on the sensor to break it loose, those open sides sensor sockets often slip when it's really stuck in there.
Old Jul 2, 2012 | 03:15 PM
BRay09's Avatar
BRay09
Cut the wires and use a 6 point socket on it with a braker bar. Heat the pipe with a torch before hand and it'll come right out
Old Jul 2, 2012 | 05:01 PM
Evan_P's Avatar
Evan_P
I sprayed mine for 3 days with PB blaster. When I finially got around to changing it I took it for a 10 min drive and took it off with a ratchet and o2 socket. Real easy.
Old Jul 2, 2012 | 05:18 PM
rla2005's Avatar
rla2005
If the truck has California emissions equipment then it will have three O2 sensors.
Mark-edge
1983 - 2012 Ranger & B-Series
Apr 12, 2017 05:24 PM
Emsand1
May 15, 2016 10:45 AM
scorpion48
Jun 2, 2012 10:11 AM
wz2wj1
Nov 24, 2005 12:12 PM
Kyle
Dec 13, 1999 06:45 PM
