Low ECT?
Old Jun 30, 2012 | 09:30 PM
KRDiesel's Avatar
KRDiesel
Low ECT?
Open interstate at 75, 90+ outside temp, AC on. My ECT is 185, Going up a long grade it will get up to 205, Towing up a long grade I will see up to 215 for a short time.
But around town, and on the highway I see 183 to 185. I replaced the t-stat with a Autozone Stant, no change, so I bought a ford one still no change.
Any ideas?
Old Jun 30, 2012 | 09:58 PM
JonArmy's Avatar
JonArmy
I usually see the same of 183 to 192, but most times it stays around 188, with the 183 it will be there for a few minutes and start going back up.
I think I heard that most of the thermostats are around 192 and they are still good at 5* difference (192 thermostat - 5 = 187 (but with CTS I only see it move in increments of 2 so it's usually at 188)).
Old Jun 30, 2012 | 10:22 PM
zhilton's Avatar
zhilton
How are you measuring the temp? A gauge through the OBD port or aftermarket? My first thought would be failed thermostat since they fail in the open position. But since you've replaced it twice...rules that out. Might be the ECT sensor, but I would think it would show some eradicate numbers and not generally "cool" ECT. But like Jon already pointed out, 5 degrees cooler isn't that big of a deal. And 215F while towing is a good number considering some of us get up above 220F rather quick under the same conditions.
Old Jun 30, 2012 | 10:35 PM
KRDiesel's Avatar
KRDiesel
Yes, I am using Torque, OBD2 adapter,
ECT, EOT, TOT, IAT and IAT2 are with in 2* of each other in the morning.
Old Jul 1, 2012 | 12:37 PM
dakotajeep's Avatar
dakotajeep
KRdiesel,
I am around the 186F most of the time unless its super hot out or I am pulling.
Thad
Old Jul 1, 2012 | 01:11 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Just out of curiosity. Do you have the Fan speed sensor up and running?
My ECT (on torque) matches SGII every time I check, so I'm happy with the accuracy of the APP.
The lowest mine gets, after the truck is warmed up, is 188*. No matter if it is highway or city.
Old Jul 1, 2012 | 01:22 PM
KRDiesel's Avatar
KRDiesel
ok, thanks for all of the info. I was just worried that i was knida low. Yes the fan is working,
Old Jul 1, 2012 | 01:29 PM
Fulthrotl's Avatar
Fulthrotl
Any ideas?
i run 192-196, haven't seen it go over 200.
idling in traffic on a 90 degree day, both
ECT and EOT will sit right under 200.
after extensive foot burying, in stop and
go traffic, it's touched 200 a couple times,
but as soon as you quit dumping fuel into
it, and dump in some airflow instead, all
is well.
Old Jul 1, 2012 | 06:01 PM
Native Tex's Avatar
Native Tex
I was having the same/similar problems and started with the thermostat but that did not help. I kept getting that little wrench light popping on on the instrument panel because the engine was too cool. I ended up having to replace the oil cooler and the EGR cooler to get the engine up to the correct operating temp.
Old Jul 1, 2012 | 07:36 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
!!!!????? Now THAT'S sure different. Most have just the opposite problem!
Old Jul 1, 2012 | 09:38 PM
Fulthrotl's Avatar
Fulthrotl
yeah, i think i'd a just lived with it.... "What, me worry?"
Old Jul 2, 2012 | 12:36 AM
BLADE35's Avatar
BLADE35
I havent heard this before wrench for too cold
What did you use to monitor temps with?????
Im thinking the wrench light came on because the ECT vs EOT Deltas were beyond the 15* spec after the ECT & EOT were past the 190*
I could be wrong but I dont think the wrench light will turn on for being to cold ECT
DanielT28
13
Dec 13, 2012 06:21 PM
Phantez
Dec 7, 2012 10:02 AM
j4henry
Nov 2, 2011 12:55 PM
aussie01
Mar 5, 2009 08:28 AM
The Grinch
Sep 19, 2003 10:16 AM
