c6 transmission
Old Jun 29, 2012 | 07:06 PM
tasboj's Avatar
tasboj
c6 transmission
Can somebody tell me what is the newest truck or car that i can find a C6 transmission trying to look for one in the junk yard hopefully we can find a good one for a straight swap with out having to open it this is for a friend thanks in advance.
Old Jun 29, 2012 | 07:38 PM
Bill W's Avatar
Bill W
we need to know what engine you plan to put it behind....
Old Jun 29, 2012 | 10:41 PM
tasboj's Avatar
tasboj
1972 f 250 with a fe 390 and c6 transmission the trans is no good that's why we are looking for one o a newer vehicle truck or car.
Old Jun 29, 2012 | 11:24 PM
Bill W's Avatar
Bill W
FE 352-390 etc, was used in the trucks from 1965 to 1976... the early FE trans would have been a COM
Cruise-0-Matic
Old Jun 30, 2012 | 03:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Bill W
FE 352 -390 etc, was used in the trucks from 1965 to 1976... the early FE trans would have been a COM - Cruise-O-Matic
No 352 engine installed in a: 1958/67 Passenger Car or 1965/67 F100/350 came with a C6.
FE/C6: Some 1966/67 390 and all 1968/71 390 Passenger Cars / 1966/67 Mercury Parklane 410 / 1966/70 428 Passenger Cars / 1968/76 F100/350 360/390.
And btw: Both the C6 & C4 were also referred to as Cruise-O-Matics thru 1979.
Old Jun 30, 2012 | 05:38 AM
jowilker's Avatar
jowilker
Bill is this really necessary, what's the point? Bill W was point on with his response.
John
Old Jun 30, 2012 | 05:51 AM
NumberDummy
If Bill W was point on, why did he type 352?
FE 352-390 etc, was used in the trucks from 1965 to 1976... the early FE trans would have been a COM Cruise-O-Matic.
It was necessary, because what Bill W typed is confusing. Said 352-390 etc, said the early FE trans is a Cruise-O-Matic.
What exact years does "early FE Cruise-O-Matic" refer to? I know, you probably do, but...who else knows?
Bottom line: No 352 came w/a C6 and no F100/350 or Passenger Car came w/a 352 after 1967.
Plus, I typed all the applications for FE/C6. How many people would know all these applications?
Old Jun 30, 2012 | 06:26 AM
jowilker's Avatar
jowilker
I presume he typed 352 because it was offered in 65 as he noted. I surely wasn't confused by his post.
Maybe you could cut some of us a little slack. Bill's post could have been written differently but it was not incorrect.
John
Old Jun 30, 2012 | 06:39 AM
NumberDummy
Different strokes for different folks. I found it confusing, you didn't. That's the way the ball bounces.
Old Jun 30, 2012 | 09:48 AM
Bill W's Avatar
Bill W
sorry your confused Bill.... i can't do anything about that. I said NOTHING about a car.
The OP said he was looking for a straight swap... Is a car C6 and Truck C6 the same? i'm sure they have a different tail shaft... the shift linkage is different.
Old Jun 30, 2012 | 01:32 PM
tasboj's Avatar
tasboj
Hey guys I didn't mean to cause a conflict. but ND is right I was confused because i'm not familiar with all the differences on a C6, I thought they where all the same, that's why I posted I wanted to do a straight swap Thinking cars and trucks use the same transmission.So now what is a (Cruise-O-Matic) like I said I'm not as smart as you guys and I understand all of you are just trying to help, So don't forget we are all friends here Thank once again because I can count on all of you.
Old Jun 30, 2012 | 08:15 PM
jowilker's Avatar
jowilker
Most of the pickups 73-76 came with C6s if they were auto. You do want a truck C6 for your truck because of the shift lever position. When in park it will run along the pan joint. A or some cars hang down at a 45º angle.
John
Old Jun 30, 2012 | 10:30 PM
tasboj's Avatar
tasboj
I need one for a friend so I will look for trucks thanks to all ho replayed to my thread
Old Jul 1, 2012 | 11:01 AM
jfmaz's Avatar
jfmaz
Personally.........I always appreciate Number Dummy's input. It is very specific and takes the guesswork out of things.
Now for my confusion: my 69 came with a short tail C6, with a yoke. When I added a DN 2 speed, I needed to get a long tail without yoke from a newer truck. How does this come into play wiht the OP's search for a new trans?
Always a little bit confused anyway, Jeff
Old Jul 1, 2012 | 03:55 PM
BobbyFord's Avatar
BobbyFord
FE's were last used in '76. Going to the boneyard for a trans will result in finding a 36 yr. old, used trans. You already have one of those, why do you want another? Deluxe overhaul kit is less than $100.
sullyda1
Jun 16, 2020 01:04 PM
JRB64
Jul 31, 2017 03:47 PM
73f250kid
Ford Truck Parts for Sale
Aug 2, 2014 02:04 AM
gary85314
Nov 24, 2008 02:16 PM
shrike
May 12, 2004 12:46 PM
