'65 Bolt help needed!
Old Jun 29, 2012 | 05:30 PM
PharmerChris's Avatar
PharmerChris
Hey guys! It's been a while since I've been around the website. Finally getting some work done on the ol' pickup. Engine bay painted, tranny rebuilt and put back into the truck, driveline rebuilt, newly rebuilt 352 sitting on a pallet waiting to be installed. Now comes my list of problems!
I have all the major parts ready to go, but I'm having a really difficult time finding the correct bolts to connect the transmission to the engine as well as for the flywheel and motor mounts. None of the hardware was saved from the initial engine tear down (not my doing - happened about 17 years ago). There is a fastener company locally that has pretty much any type of nut, bolt, screw or washer you could ever want. My problem is that I can find the information on the original Ford part numbers, but that doesn't help much if I don't know what size bolt I need or how long!
Any one have this information available? I'd really appreciate the help. The truck is coming together nicely thanks to the help of a former mechanic turned pharmacy technician co-worker of mine :-)
Thanks in advance!
Chris
Old Jun 30, 2012 | 12:14 PM
camperspecial65's Avatar
camperspecial65
I think I have some bellhousing/engine bolts...as for flywheel bolts...your local parts house typically should be able to get those as they stretch and arent recommended for reuse...The engine mount bolts...which once specifically are you needing ??? The insulator to block bolts or the insulator to frame fasteners??
- cs65
Old Jun 30, 2012 | 07:03 PM
C G B's Avatar
C G B
No luck with the dealership even? They should at least be able to tell you what size you need providing they even have the info on hand.
Another option for the flywheel bolts, and this might be pricey, but Id take a look at ARP. They make bolts for just about anything. Cant hurt to call them.
Keep in mind you can just use hardware from the hardware store for anything that is not critical. Flywheel = critical. Trans and motor mount bolts = not critical. To find the size you need, just use a vernier caliper to measure the depth needed into the block, add the thickness of the trans/motor mount, figure out the bolt size, and head to the hardware store. Id go about a 1/8-1/4" shorter than the total needed length. As a hardware store bolt doesnt have shoulders on it, and most places dont have them, Id at least use a flat washer as well.
Ive used grade 8 hardware before in my much younger days. Never had any issue, but I dont think Id do it again. Lost the bolts that hold the flex plate on my '73 F250, used grade 8 and blue Loctite from the local hardware store and it worked fine.
Old Jul 1, 2012 | 12:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford part numbers and/or applications for bolts list the thread sizes, not the wrench sizes.
1965/76 FE F100/350 & 1965/71 FE Passenger Cars: 350329-S2 .. Bolt 5/16" -18 x 13/16" long =
C5AZ-6375-K .. Flywheel / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle-Use with 11" clutch.
C5AZ-6375-L .. Flywheel / (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle-Use with 11 1/2" clutch.
Most partsguys in dealerships are not going to take the time to look up parts for a 47 year old truck! Most will say OBSOLETE the second the year is mentioned.
Many are "battle hardened" have been down this road before, look this jazz up, give customers the info, and out the door they go, without buying anything.
More than likely partsguys will say they don't have a parts catalog this old. Time is money, partsguys are paid on commission, so...
They aren't gonna waste time looking up Standard Parts (ie: nut, bolts and etc) because they are aware the customers only want the specs.
Even if the customers would be willing to buy, dealers aren't gonna have these parts, because...since the early 1980's, almost all Standard Parts are metric.
Old Jul 3, 2012 | 08:22 PM
PharmerChris
I knew I could rely on you guys to help me out! I have zero experience dealing with this kind of project. I have a co-worker who is a former mechanic and he's been helping me out a lot by telling me what I need to track down. The hard part has been actually tracking stuff down!
I'm going to see what I can find locally tomorrow and will post if I have any more questions.
I'll get some pics of my progress uploaded soon as well - I know you all like the pics!
RamblinMan1963
24
Apr 25, 2019 02:39 PM
'66BlueBlood
Mar 30, 2018 05:35 AM
rehrlich
1997 - 2003 F150
Dec 4, 2014 04:05 PM
wtroger
Jan 17, 2011 03:28 PM
Gidde Up
May 17, 2003 12:13 AM
