Headers, O2 Sensor and Thermactor
Old Jun 29, 2012 | 03:43 PM
Finger__Rachet's Avatar
Finger__Rachet
I'm going to rebuild my 460 in my 1988 F250 XLT Lariat Extended cab 4spd w OD (Z) transmission (4.10 rear end, not that it matters). I was thinking about headers and dual exhaust as an upgrade. However, after looking it over, seeing the thermactor/air pump inputs into the exhaust downstream of the O2 sensor and the placement of the O2 sensor after the Y, I'm having second thoughts. I've read enough comments on various posts where I'm not interested in removing the Thermactor/Air pump stuff.
So here are my questions. If I go dual exhaust, what do I do with the O2, pick one side for the O2 and let the other go without? And the same question applies to the thermactor ports in the exhaust, dual port them? That seems like overkill.
All in all, after seeing the setup, it seems to beg to stay as a single exhaust system. In that case, are headers even worth it?
Old Jun 29, 2012 | 04:56 PM
GNR22's Avatar
GNR22
For the O2 sensor, pick one side and stick it in. It only requires 1 input. As for the line into the exhaust, most people just cut that and don't hook it back up. it shouldn't throw a code or anything. I have it removed on my truck with no ill effects.
Old Jun 29, 2012 | 11:28 PM
Finger__Rachet
So just zip line the lines that I remove to the frame and let them blow? I think that would still keep the pump pushing air into the exhaust manifold which is good.
Old Jun 29, 2012 | 11:55 PM
GNR22's Avatar
GNR22
Yessir. That'd be acceptable
Old Jun 30, 2012 | 07:34 AM
Conanski's Avatar
Conanski
A properly designed single exhaust system will perform just as well as a well designed dual, the only difference between them will be the sound you get. Upgrade the size of the tubing slightly and use mendrel bends instead of the factory compression bends or worse again the crinkle bent stuff you see from the muffler shops and you'll see performance gains. As already mentioned insert the O2 into the passenger side header collector and the motor will run perfectly(speaking from experience here), but if you just let the air plumbing hang you're gonna have some odd noises coming from under the hood so I'd suggest you re-attach it but again just on the passenger side in the stock location. Of course if you don't put a cat on the truck with the new exhaust then there is no point of the air injection system at all, so you may consider removing the whole works.
Old Jun 30, 2012 | 07:48 PM
jayft8's Avatar
jayft8
1st Ratch, Welcome to FTE
and come join us in the Texas Chapter!
I did this job on my '86. I used Hooker Competition long-tubes, and put the O2 sensor on the passenger side collector. I cut the foot off a pair of pantyhose and zip tied it over the end of the cut off end of the air tube and tied it back out of the way on the passenger side frame rail. The truck ran just great and I never had a single problem from it. Ever. It was superb.
Just like Conanski said, a single exhaust is just fine. You can run more exhaust flow through a single 3" pipe than you can two 2" pipes. I have a neighbor that runs a muffler shop. He fabricated a custom dual system for my '86, but we put a single on my '03. Both offered great performance gains. Just make sure you choose your muffler wisely (we like Magnaflow if you're open for suggestions) and don't forget to pay some attention to the intake end of things as well. If your '88 was like my '86 it came from the factory with an intake design that was very nearly a C.A.I. and so a K&N drop-in worked just super great to really open my little baby up!
1995F250351
Feb 5, 2015 08:24 PM
lariat87
Exhaust Systems
Mar 15, 2007 11:22 PM
jesserowley2000
Exhaust Systems
Mar 29, 2003 05:29 PM
89XLTBronco
Exhaust Systems
Mar 10, 2002 06:10 AM
mudinford
Jun 17, 2000 10:50 AM
