bent crank..
Old Jun 28, 2012 | 10:29 PM
Lumpy78's Avatar
Lumpy78
bent crank..
got a 73 f250 with 390 and in the process of rebuilding it, got it tore down and it has a bent crank. Just wondering what would cause that?
Old Jun 28, 2012 | 11:02 PM
mark a.'s Avatar
mark a.
How do you know it's bent ? Are you saying it wont turn in the block ?.
Old Jun 29, 2012 | 12:05 AM
piratius's Avatar
piratius
Bending a crank is usually the result of something nasty, like hydro-locking the motor (which also usually eats connecting rods!).
I don't think I've ever seen anyone bend a crank from normal driving. I suppose you could also TWIST the crank if you had big tires and dumped the clutch while trying to pull something (like on pavement) - but again, that's totally weird!
Like Mark asked - is the crank visibly bent? Can you give us some pictures?
-Brad
Old Jun 29, 2012 | 12:44 AM
Stinky7-11's Avatar
Stinky7-11
-Brad
I would say you would see your driveshaft flying into the woods first. I have seen engine builders check cranks for straightness and call them bent when just a few thou. out. I was also told that when not installed in a block you can knock them out a few thou. pretty easy. You would never see that though just looking at it.
Old Jun 29, 2012 | 10:26 AM
mark a.'s Avatar
mark a.
Yep, if it was bent more than a few of .001" it wouldn't even turn in the block.
Old Jun 29, 2012 | 07:11 PM
4x4 Bart's Avatar
4x4 Bart
If you lay them horizontal on the shop floor they will start to bend in a short time. I like to leave them in the block or stand them on end without the counterweights touching the wall.
Old Jul 8, 2012 | 10:43 PM
Lumpy78's Avatar
Lumpy78
We had a machine shop check it and they confirmed it, it was a mud racer and had a 3600rpm stall converter, punched .30 over, stage 3 cam, high rise eldlebrock intake, double pumper holly carb 750cfm, bout 400 dollars in work and parts on each head, msd ignition, and to top it off a B&M slap shifter , also 35" tires all the way around.
427 fordman
Jan 22, 2011 01:22 PM
boxer.fan
Aug 19, 2009 05:50 PM
thunderguns71
Oct 7, 2004 11:02 AM
51dueller
Flathead V8 & Flathead 6
Apr 11, 2004 07:37 PM
Crazy_John69
Mar 23, 2002 02:23 PM
