76 F250 hard/no start - Ford Truck Enthusiasts Forums
Old 12-16-2017, 10:01 PM
JSMskater's Avatar
JSMskater JSMskater is offline
JSMskater is starting off with a positive reputation.
Where to begin... I bought this truck (1976 f250, 360 5.9L with c4 auto trans) running for 500$. Drove it home (120 miles away), parked it a few days, noticed a fuel leak, fixed the fuel line, and now it won't start.
I've replaced the battery, starter, and solenoid, mostly because I planned to anyway. It merrily cranks, and if I give it a spurt of gas or hold the accelerator down for a second while cranking, the engine will start and rev, but as soon as you let go of the key from "start/crank" just to "run/on" it dies immediately. If i hold the ignition switch to "start/crank" and keep holding it there while giving it gas, the engine will rev and run otherwise normally but I don't do this for very long out of fear of damaging the starter or flywheel/flexplate.
Since it started and idled and ran before just fine (little hard to cold start but it would start and hold an idle) I'm leaning towards it being a spark/ignition issue, though I'm sure the carb can use an adjustment.
I've contemplated replacing the ignition switch next but I'm looking to you experts for some additional advice or checks to perform.
Old 12-16-2017, 11:07 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Letting the key go from start to run and it dies sure sounds like a elec issue. And I would suspect a bad ignition switch.
I believe the last diagram is a 78/79.
You can get a new outer part of the switch and then search for the thread that tells you how to pop out the center tumbler from the old switch and install in your new switch.
FTE member says..." You can easily test the starter solenoid and the switch.
First, the switch. You'll need a partner and a multimeter.
-There is a 'hot' (12V +ve) wire that is off (0V) when the key is off and on (12V) when you have the key in the start position. You just need to check if you are indeed consistently getting 12V when the key is in start. So, multimeter with one lead on ground and one lead on the wire from the key. This should be a thin (16GA?) wire coming into the 3rd post on the solenoid. Side note: Essentially a solenoid is simply a relay that uses a low current 'switch' voltage to create an electromagnet that closes a switch inside and completes the high current circuit, making the starter spin. Once you confirm that there is indeed 12V coming from the key when it's in the 'start' position, we've ruled out that the key switch is bad.
Next, the solenoid. Like I said, the solenoid is just a switch that uses low current to complete a high-current circuit (the starter). It can go bad without warning, and it's entirely possible and likely that it's bad. So, to test the solenoid (after you've confirmed you're getting power from the switch to the 3rd terminal on the solenoid) you simply take a jumper cable and clamp one end onto one side of the solenoid (12V in from battery) and touch the other end of the cable to the other post of the solenoid (12V out to starter). The engine should immediately turn over (expect a few sparks, no big deal). MAKE SURE IT IS IN NUTRAL IF IT IS A STANDARD TRANSMISSION.
If the key checks out good, and the solenoid test makes the engine spin over, then the solenoid is bad.
If the key checks out bad, you can verify solenoid operation by taking a small bit of wire and going from the +ve terminal of the battery and touching it to the 3rd terminal on the solenoid (where the key goes in) and it should energize the solenoid and turn over the engine."
Old 12-17-2017, 01:56 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by JSMskater View Post
I bought this truck (1976 F250, 360 with C4 auto trans) running for $500.
It's a C6. C4's were not installed with FE engines (360/390 etc).
Old 12-17-2017, 06:55 PM
JSMskater's Avatar
Quote:
Well, Chilton seems to disagree with that.
See code G- C4
See Vin plate- trans code G
Old 12-17-2017, 07:50 PM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is online now
Jklnhyd is a name known to allJklnhyd is a name known to allJklnhyd is a name known to allJklnhyd is a name known to allJklnhyd is a name known to allJklnhyd is a name known to all
Chilton is notoriously flawed.
From what I found on a quick Google search, G means a 3 speed automatic, not necessarily C4 or C6.
Old 12-17-2017, 08:00 PM
fuzzybob's Avatar
fuzzybob fuzzybob is offline
fuzzybob is gaining momentum as a positive member of FTE.
JSMskater, welcome to the forum. When mine was doing about the same thing.... turned out to be the pick-up coil in the dizzy. Good luck on your project!!
Old 12-17-2017, 08:05 PM
Jklnhyd's Avatar
Old 12-17-2017, 08:12 PM
JSMskater's Avatar
Great! That should make it easy to fix stuff using it...
Good to know- looks like someone posted a nifty chart- thanks! This should help identifying it for sure.
Old 12-17-2017, 08:13 PM
JSMskater's Avatar
Quote:
Thanks! I will check that too.
Old 12-17-2017, 08:14 PM
JSMskater's Avatar
This is awesome thanks
Old 12-17-2017, 08:30 PM
jakeharp's Avatar
jakeharp jakeharp is offline
jakeharp is starting off with a positive reputation.
C4/6
Was curious about the C4 application.... and was gonna chime in, but Rich covered the first few tests you need to do... then I would move onto coil and Dizzy... Love me some FE !
Old 12-17-2017, 08:33 PM
Filthy Beast's Avatar
Filthy Beast Filthy Beast is offline
Filthy Beast has a good reputation on FTE.Filthy Beast has a good reputation on FTE.Filthy Beast has a good reputation on FTE.
I'll reserve my "troubleshooting the stator tests" until you've done the tests recommended by Rich...AKA 77&79F250.
Do you have the DSII system in yer '76?
Old 12-17-2017, 10:27 PM
JSMskater's Avatar
Hard to say, I know it does have a large plug coming off the distributor indicative of the breakerless system - the manual seems to think for 76 its just called a breakerless ignition and doesnt become duraspark II until 77 but as someone said above chilton apparently isnt accurate on some of this. The picture labeled duraspark II in the manual looks identical to my distributor so I'm fairly certain it is.
Old 12-17-2017, 10:32 PM
JSMskater's Avatar
Quote:
Yeah I have no idea what it has, just going by the vin and what the manual said; but one poster provided an awesome identification chart so I'll crawl under and report back and settle the debate.
Ill run these tests (thanks everyone!) And report back.
Ill get some pics posted as well, and a link with a walkaround video.
Old 12-17-2017, 10:35 PM
Jklnhyd's Avatar
Welcome to FTE.
Weak start/crank 89 4.9 steelholder 1987 - 1996 F150 & Larger F-Series Trucks 5 06-01-2017 09:21 PM
1995 Ford F-350 7.5 460 misfiring / no power / stalls Guillaume Koe 1987 - 1996 F150 & Larger F-Series Trucks 4 02-11-2017 01:44 PM
Another no start toyotaguy 1999 - 2003 7.3L Power Stroke Diesel 15 08-06-2016 09:47 AM
6.0 Starts then won't start after it's warm. phantomphixer 6.0L Power Stroke Diesel 15 02-19-2016 11:19 PM
6.0 won't start/crank after oil cooler rebuild. Brian Carter 6.0L Power Stroke Diesel 13 01-26-2016 11:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
