Sponsored by: Real Truck
squeaking when accelerating
Old Jun 28, 2012 | 11:55 AM
jeremypatrickreed's Avatar
jeremypatrickreed
Just bought a 01 ford f250 5.4 2wd and lately has started squeaking. It's coming from the engine but can't pin point it because only does it while driving when I accelerate quits when i let off. I've replace idlers pulley and belt still does it any help would he appreciated thanks
Old Jun 28, 2012 | 12:03 PM
drey04's Avatar
drey04
Is it a "chirping" type noise? Check your exhaust manifold studs. My truck has been chirping/squeaking for that last 3-4 weeks. I finally took in to my mechanic buddy. He says I got broken studs....exhaust leak. I would start by checking your studs and go from there.
Old Jun 28, 2012 | 12:08 PM
kd0axs's Avatar
kd0axs
Sounds to me like a U-joint starting to go out.
Old Jun 28, 2012 | 06:29 PM
jeremypatrickreed
Well all the studs are good and the u joint is tight but its coming from the engine somewhere. The u joint would squel if I let off the gas right?
Old Jun 29, 2012 | 01:27 PM
rjanveaux's Avatar
rjanveaux
Nope, when it is under load. and you could get some vibration also.
Old Jun 29, 2012 | 02:20 PM
drey04's Avatar
drey04
I've heard that the cam sensor or crank sensor (something like that...) can chirp when going bad ???
William Davis
6.4L Power Stroke Diesel
Jun 26, 2019 10:53 AM
Ziob
Nov 16, 2015 09:08 AM
joneszee
Modular V8 (4.6L, 5.4L)
Jan 12, 2015 05:17 PM
4.9inline6
Apr 30, 2010 09:35 AM
xcopterdoc
Nov 26, 2002 10:10 AM
