Lubrication
Old Jun 27, 2012 | 09:22 PM
rusbukt's Avatar
rusbukt
Lubrication
Need to find lube specs for my 65 3/4 ton. Or does someone have them handy? 352 motor, Dana 60 rear-end and manual 4 speed trans. I'm running it in the California heat.
Old Jun 27, 2012 | 11:58 PM
garbz2's Avatar
garbz2
30 weight in the trans, 30 weight in the engine and 90 weight hypoid in the rear.
Old Jun 28, 2012 | 02:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Lubing has more to do with it besides the weights of gear lube and oil. I disagree on the oil, 10-30 was the most popular back then, excellent for all season motoring, so it still applies today.
What about all the zerk fittings? The info/locations are in the owners manual, but 1965 isn't repro'd, but 1966 is and the locations are the same.
Now, take into account FoMoCo's "Lifetime Lubrication" wheeze, where they inserted rubber plugs into some of the zerk fitting holes.
How many peeps are aware of these plugs in today's world? How many know where the plugs are located?
Old Jun 28, 2012 | 08:35 AM
rusbukt's Avatar
rusbukt
Thanks men.
Lifetime Lubrication! Is this why my 2005 ball joints are going bad after only 65000? LOL
Lack-of-zerk.
Old Jun 28, 2012 | 12:45 PM
1972RedNeck's Avatar
1972RedNeck
Really? I always run 80w-90. I guess I need to change the oil.
Old Jun 28, 2012 | 08:32 PM
garbz2's Avatar
garbz2
Np435 takes 30 weight as does a T18.
Man that should make for some really hard shifting in the cold Montana mornings.. LOL
Some newer manual transmissions take ATF.
Garbz
Old Jun 28, 2012 | 11:12 PM
rusbukt's Avatar
rusbukt
Rodger that. I remember back in Alaska when you had to keep your truck plugged in all night just so it would move in the morning. One heat pad on you trans. one on your oil pan a block heater. Nothin funner than driving down the road first thing in the morning with one side of each tire frozen flat and stiff shocks. Spilling your coffee in your lap was a good thing at 40-50 below zero.
Old Jun 29, 2012 | 08:00 AM
rogue40's Avatar
rogue40
I spent '74 and '75 in Fairbanks when I was a kid. I've seen it get down to -72!
brrr
Old Jun 29, 2012 | 09:55 AM
daveengelson's Avatar
daveengelson
Garbz
Who would have thunk it, again learned something new about my 65, which I purchased in the early 70's, along with the shop manual where under the lubrication section notes to use 30W below 10 degrees temp, and 50W above 10 degrees. Been putting in Hypoid 85-90 GL 4-5, if it comes down to changing again guess I'll have to try the 50W non detergent?
Old Jun 29, 2012 | 04:19 PM
Buzz44's Avatar
Buzz44
I use the 80-90 up here in Washington state. Dont remember ever having trouble shifting with sub zero temps. The place I did find problems was with a 61 Falcon 6 with a 3 on the tree. Very stiff and hard to shift until driven a few miles on freezing winter mornings. Now that was a PITA in traffic.
Old Jun 29, 2012 | 04:28 PM
1972RedNeck
Np435 takes 30 under 10* F weight as does a T18.
50w above 10*
-1966 F100 - F350 operators manual
It actually shifts quite good. It makes really sloppy transmissions feel a bit more tight.
Where do I get 50w oil? What oil is equivalent to it? (the newfangled number system)
Old Jun 29, 2012 | 06:30 PM
daveengelson
Yep, as I mentioned, been running 85-90W in T18 for the past 40 plus yrs. w/ no problems. Recently changed to 85-90 GL4 and doubt this ole timer will need to do it again; if so, possibly give the 50W non detergent a try.
tinman52
Sep 10, 2019 10:11 PM
MClogger
Large Truck
Mar 19, 2016 06:49 PM
80broncoman
Large Truck
Jul 18, 2011 07:56 PM
99F150
Oil & Lubrication
Sep 21, 2004 10:11 AM
78f250lj
Jan 10, 2003 11:59 PM
