T98 trans oil?
Old Jun 12, 2015 | 10:12 AM
tinman52's Avatar
tinman52
Welder User
T98 trans oil?
What type lube goes in the (1951) T98 4 speed? Is 90wt gear oil ok?
And how much lube required to fill it?
Thanks!
Old Jun 12, 2015 | 10:59 AM
harleymsn's Avatar
harleymsn
Scott, I didn't find the weight, but it holds 8 pts when dry.
Old Jun 12, 2015 | 11:16 AM
harleymsn's Avatar
harleymsn
OK, the only thing I could find was a post from 10 years ago that said the service manual for a 1960 F100 with T98 calls for 50wt.
https://www.ford-trucks.com/forums/4...il-to-use.html
Old Jun 12, 2015 | 11:52 AM
tinman52's Avatar
tinman52
Welder User
Thanks Joe, I was thinking 50wt, but can't find any locally. Maybe mix 90 and 30wt?
It's a truck that only gets used on the farm in summer, so it shouldn't be too critical...
Old Jun 12, 2015 | 11:57 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The usual oil for Ford trannies back then was straight weight 140, GL-1. That's hard to come by, StaLube makes it and NAPA's can order it (p/n SL 24228 (qt) SL 24238 (gal) )but it's pricey. You can also buy off Amazon.
Lots and lots of debate on many forums over whether commonly available GL-5 gear oils are OK for use with brass synchros. I just had to refill my trans so I did a lot of web searching. I believe the story is, most GL-5 used to contain "active sulphates" that would eat brass when hot. GL-4 didn't allow use of active sulphates, so it was safe. But in modern times, almost all the Brand Name oil co.'s have switched to inactive sulphates for their GL-5, and many say right on the bottle they are safe for copper.
I ended up going with SuperTech 85w140 from WallyWorld, which has the statement about being safe for copper in manual trannies. I am pretty sure that's what I was running in my trans for the last 8 years, and when I had it apart, the brass looked good (active sulphates stain the brass to a blackish color).
YMMV...
Old Jun 20, 2015 | 10:20 AM
petemcl's Avatar
petemcl
This is from the Nowak Conversions -The Novak Guide to the Borg-Warner T98 Transmission website:
Old Sep 10, 2019 | 10:11 PM
matthewq4b's Avatar
matthewq4b
Originally Posted by petemcl
The Novak guide is primarily for the units Jeep used... Even Ford changed to 80W 90 later on in the 50's . But in the early units 140W summer is what is and was called for. As I recall there was another individual with an 48 or 49 1.5 ton having the same issues and filling 140W resolved them. I think these early units had more clearance just due to manufacturing tolerances. I believe if you replace the synchros and rebuild to current specs with modern synchros then 80W/90 is the way to go.
Twanstyle
Aug 9, 2013 12:47 PM
kevmon66
Feb 25, 2012 09:37 AM
ford5o
Mar 21, 2010 10:18 PM
plow/truck
Sep 23, 2006 08:55 PM
78f250lj
Jan 10, 2003 11:59 PM
