Fuel Leak
Old Jun 27, 2012 | 08:00 PM
john_michael23215's Avatar
john_michael23215
Fuel Leak
Ive looked at my fuel line from my fuel filter to my passenger side head and the banjo bolt its all dry including the section of line going through the P clamp it seems to b coming from my valve cover any thoughts before I tear into it? Its a 99 f250 7.3
also my truck is running 100% thats why i'm puzzled
Old Jun 27, 2012 | 08:02 PM
timmyboy76's Avatar
timmyboy76
the p/s fuel line, run'n thru that "P" clamp, rubs and causes a hole/crack, in that location. It could be your culprit or the fuel bowl itself is leaking, and pooling up over in that area.
Old Jun 27, 2012 | 08:04 PM
john_michael23215
The valley is dry though i took the turbo spider off and the p clamp to make sure too and i had no such luck
Old Jun 27, 2012 | 08:31 PM
BigAlsPSD's Avatar
BigAlsPSD
Is it leaking from the valve cover or the fuel rail atop the valve cover?
Old Jun 27, 2012 | 08:33 PM
john_michael23215
i thought the fuel rail was inside the valve cover
Old Jun 27, 2012 | 08:36 PM
BigAlsPSD's Avatar
BigAlsPSD
Sort of, or I should say both...you have rail plugs inside the head, but you have fuel ports along the head as well.
sleek122
Jan 9, 2013 07:45 PM
davidlea
Dec 14, 2012 10:36 AM
john_michael23215
Jun 29, 2012 07:03 AM
matty_tex
Jun 29, 2011 02:35 PM
swaybar
Dec 29, 2008 07:25 PM
