engine code reading
Old Jun 28, 2012 | 11:34 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Where do you get the spring from?
Old Jun 28, 2012 | 11:36 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I got mine from one of the Ford vendors here.... can't remember which one....duh!
Old Jun 28, 2012 | 11:38 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Is it a dealer part?
Old Jun 28, 2012 | 11:41 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yeah, it is....hold on - I was looking for P/N....
3C3Z 9T517 AG / 1854267C94---"BLUE SPRING" Fuel Pressure Regulator (6E7Z 9C165 B / 1854267C94 No Housing Cover)*
I got the one WITH the housing cover... I always screw up something so I made sure. It wasn't THAT much more in cost. Just remember when you remove it to hold on to the cover...there's spring tension there.
Old Jun 28, 2012 | 11:43 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I've found one at Riffraff. Do I need the one with or without a cover? 29 w/o, 59 with.
Old Jun 28, 2012 | 11:47 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You don't need the cover.
Old Jun 28, 2012 | 11:48 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
As I said...you don't NEED the cover. As it was, I didn't need it.
Hi Steve!
Old Jun 28, 2012 | 11:53 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Okay, I'll order that one. I'll check on that chafing on the #1 injector also. I'll let you know what I find!
Old Jun 28, 2012 | 11:56 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
OMG. Ford wants $100 for that kit! Going to Riffraff.
Old Jun 28, 2012 | 12:36 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I think that's where I got mine too.... don't blame ya!
Old Jun 28, 2012 | 01:47 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It's seriously a 30 minute job, if you're lazy with it.
https://www.ford-trucks.com/forums/1...ue-spring.html
He show's a really in-depth job, removing the upper radiator hose and the regulator housing from the fuel lines. Leave the rad hose in, just pull it down and out of the way with a ratchet strap. Leave the cover on, just gently pull it back enough to get the only spring out, swap the gasket, and put the new spring in. Blue loc-tite on the screws, snug it up, done.
Old Jun 28, 2012 | 01:50 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Thanks for the link Bryan!
Old Jun 28, 2012 | 01:59 PM
  #28
texastech_diesel
Token Redneck
NP, just be sure to hit up Rusty with some reps for it. He took the time to take it all apart and then edit and post the pics to show what it all looks like, just so that I can go around saying "skip steps 3-7" He has an oil cooler thread/album that is worth it's weight in picture gold for the visual learners.
Old Jun 28, 2012 | 02:01 PM
  #29
67nukeford's Avatar
67nukeford
Veteran: Navy
Allready hit him with reps, and subscribed to the thread!
btdrygulch
1983 - 2012 Ranger & B-Series
Mar 26, 2025 09:35 AM
GorillaNuts
Aug 31, 2012 07:14 PM
fdaugher
Nov 27, 2010 07:02 PM
eric777
Sep 18, 2006 06:55 PM
jacaroo
Sep 23, 2004 06:06 PM
