engine code reading
Old Jun 27, 2012 | 12:45 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
engine code reading
I have an 06 with the 6.0, and it threw me a check engine light last night. I'd like to read the code. I have a code reader for the OBD II, will this work on this truck?
Thanks!
Old Jun 27, 2012 | 01:07 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The scanner needs to be CAN compliant to work. What kind do you have?
Old Jun 27, 2012 | 04:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
One sure way to find out. Plug it in and see what it says. I don't think it's possible for it to hurt anything if it says OBDII on the device or in it's manual. If it says ther are 3 codes and it only shows you what 1 of them is, you'll know it's not reading manufacturer specific info.
Old Jun 27, 2012 | 04:48 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
It's an Innova OBD II CAN. I'll give it a shot, and see what happens.
Old Jun 27, 2012 | 04:59 PM
Rusty Axlerod
I had one of those, a 3130 I think, it had the ABS feature and "emission readiness test". It read codes ok but no "live data" so I sold it to a guy at work. It read the manufacturer specific codes but didn't have definitions on the screen, It would display the code and you would have to look them up online or whatever.
Old Jun 27, 2012 | 06:40 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Your reader will read your codes.....reads live data too.... I've got one and it does great.
Old Jun 27, 2012 | 07:54 PM
Rusty Axlerod
Innova has several different models from $89 to $280 or so.
Old Jun 28, 2012 | 10:28 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Okay, code is "#1 cylinder injector circuit low". Cleared it, and it came back this morning.
Old Jun 28, 2012 | 11:04 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Pat, it sounds like a bad (or failing) #1 injector. Do you run any kind of fuel (or oil) additive in it? What brand/weight oil? Miles on engine?
Rusty Axlerod
The cylinders of the 6.0L Power Stroke are numbered from the front on the right side 1, 3, 5, 7 and from the front on the left side 2, 4, 6, 8. So front cylinder passengers side. Check harness for chaffing I think the alt mount on the intake is close at the injector end. How many miles on the truck?
Old Jun 28, 2012 | 11:11 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Also Pat...have you installed the "blue spring" yet?
Old Jun 28, 2012 | 11:19 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
80K. What's the blue spring?
Old Jun 28, 2012 | 11:27 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Fuel pressure regulator spring.... recommended mod to increase fuel pressure.
Old Jun 28, 2012 | 11:29 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Oh, okay. That might be one of the things that will be done later this summer, when I get the heads studded. I'll talk to the shop about that.
Old Jun 28, 2012 | 11:31 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You can do it in less than an hour.....
