95 midship tank
Old Jun 26, 2012 | 11:05 PM
jaagen's Avatar
jaagen
95 midship tank
hey guy's newbi here. I have a 95 f250 4x4 and the front tank doesn't work it registers empty but i hear what sounds like the pump. not sure if it the sender or the whole assembly? any insite would greatly help
Old Jun 27, 2012 | 09:41 AM
Intimnasc's Avatar
Intimnasc
Does it start and run onthat tank? If so you can replace just the sender but you may also have a bad connection somewhere.
Old Jun 27, 2012 | 10:13 AM
subford's Avatar
subford
Bad connection would make it read full.
Sounds like a sunk float.
Old Jun 27, 2012 | 02:52 PM
jaagen's Avatar
jaagen
ya the front tank does work fine from what I can tell,It just reads empty. Where are the connection that I should look at?
Old Jun 27, 2012 | 03:54 PM
subford's Avatar
subford
There are no connections to look at.
There may be a wire shorted to ground if it reads passed empty (pegged).
If it just read empty then the wiring is OK and the the float is all the way down in the tank.
More than likely the float has a hole in it if it just reads empty and not pegged.
Old Jun 28, 2012 | 02:40 PM
jaagen's Avatar
jaagen
You are right the gauge just reads just empty not pegged. Now the next question is is it as easy to drop the tank on a ford as it is on a chevy truck? I appericate all the help
Old Jun 28, 2012 | 02:57 PM
subford's Avatar
subford
I do not know. I have never dropped a tank on a chevy truck. The last chevy I have worked on was in the year 1974. It had the fuel tank behind the seat, it was a 1962 PU.
But you have a choice, you can pull the bed with about three other friends or if the tank is near empty you lower it from under the truck. I like to take the bed off.
Old Jun 28, 2012 | 08:36 PM
jaagen's Avatar
jaagen
A BIG THANK YOU to you SUBFORD for all youe help.
Sax Genius
Aug 28, 2010 08:59 PM
MustangMatt96GT
Jan 26, 2009 11:08 PM
SuperCharger
Apr 3, 2007 09:05 PM
chainsaw
Feb 8, 2005 11:30 PM
