4v intake manifold
Old Sep 20, 2006 | 06:43 PM
cruzin55f100's Avatar
cruzin55f100
Question 4v intake manifold
i currently have a 239 with a 2-barrel carburator, will an intake from a 292 fit and will i see any type of improvements in performance?
Old Sep 20, 2006 | 07:18 PM
Randy Jack's Avatar
Randy Jack
I don't know about the interchangeablity of those manifolds, but others here will.
However, regarding performance, the most common mistake made with carburation is to over-carburate. A 4 barrel carb on a stock 239 will make it a real dog. It will make the performance worse. It will suck a lot more gas, also. My advice: stick with the 2 barrel.
If you want improved performance, improve breathing efficiency. The best way to do this is to match port the intake and add match-ported headers. Cleaning up the head ports to smooth them is also a good move. Once that is done, then you could look at adding carb cfm, but a longer duration cam will be needed to maximize the larger carb performance.
mainman
2004 - 2008 F150
Dec 31, 2009 08:11 PM
Bigblockexplorer
Feb 2, 2008 02:09 PM
lud04X
Jul 13, 2007 02:56 PM
fordeverpower
Oct 31, 2005 03:04 AM
fordeverpower
Jul 1, 2005 05:17 AM
