Engine Knocking
Old May 7, 2003 | 10:30 PM
smangold's Avatar
smangold
Engine Knocking
Hi,
I have a '99 3.0L V6 Ford Ranger with an automatic transmission and the
engine seems to knock a lot. The engine knocks mostly when I climb hills.
These aren't huge hills either, just the typical hills you find in the Las
Vegas valley. It also knocks a lot when I try to accelerate. I use the 87
octane that the user manual recommends.
Is anybody else experiencing this knocking problem?
Does anybody have suggestions on how to limit the knocking?
I have yet to try anything to rectify this problem.
Old May 7, 2003 | 11:13 PM
mrwizard's Avatar
mrwizard
Engine Knocking
Do a search on knocking or pinging. There have been all kinds of threads about this problem.
Old May 8, 2003 | 09:49 AM
bassaway's Avatar
bassaway
Engine Knocking
Try running a higher octane. Doing so usually gets rid of any knocking or pinging.
Old May 8, 2003 | 11:30 AM
Ken00's Avatar
Ken00
Engine Knocking
Welcome to FTE!!!
You should be able to find what you need from a search but if you still need more information let us know.
Old May 9, 2003 | 01:00 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Engine Knocking
In my travels I recall seeing a TSB for knock/ping in the 3.0L; I think there is a new coil pack out with a higher voltage. I'm not sure if it applies to your rig but that's easy enough to determine.
You may also want to do a search for a company called Alldata. They offer TSB's and other service data to shops and the rest of us for a fee. However, they were kind enough to provide some online samples of their product which included mid 90's Rangers. Just get in there and look up TSB's on the subject for a 93+ Ranger with the 3.0 and the TSB will tell you what years it applies too
Old Jun 25, 2004 | 02:18 PM
papsmear1's Avatar
papsmear1
Fuel Filter
I had the same problem, usually knocked at highway speeds when accelerating. I tried running premium, worked, but was costly. Then i did a tune up, changed oil and filter, and the fuel filter, works great now. no knock, been like this for a while now. I would replace the fuel filter if i were you, worked for me with the 4.0 with 133k miles
Old Jun 25, 2004 | 09:26 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
You'll find a bunch of relevant info on 3.0L & pinging in Section V of this: 3.0L Technical Information & Tips
kkelly1121
Jan 3, 2009 06:06 PM
mooneyman9
1997 - 2003 F150
Jan 7, 2006 09:20 AM
mooneyman9
1997 - 2003 F150
Dec 29, 2005 07:48 AM
jcgriffin
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
42
Mar 24, 2004 11:06 PM
