service engine light......overboost !!!
Old May 7, 2003 | 09:43 PM
frankoholic78's Avatar
frankoholic78
Hi wondering what the best most popular way to not have the SES (ServiceEngineSoon) LIGHT to come on with a MAP sensor code, BECAUSE OF OVERBOOST !!! I am running a micro tuner on the 80 HP setting on an early 99 powerstroke... Saw this on E-bay would this be the trick...thanks Frank
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2414535323
Old May 8, 2003 | 09:44 AM
psd tech's Avatar
psd tech
I beleive that is a preset parameter in your pcm. Mine did that, the lamp was on for about 5 seconds then went out. It turns on at about 25 psi of boost. I don't think that can be changed, if it could I would think that the issue would have been adressed in the chip/programmer.
Old May 8, 2003 | 11:42 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You have two options for controlling the SES light for overboost.
1. 4.7 v Zener diode. The overboost light is set at approximately 24psi, which is a 5 volt imput signal to the MAP sensor. The diode installs in the map sensor wire and shunts off anything over 4.7 volts, thereby eliminating the ses light.
The downside is it might affect other sensors, but none that I ever noticed, and some have reported (including myself) that the diode can slightly limit top end performance by failing to stop limiting the signal when it drops below 4.7v
Total cost for the ZD, less than one dollar.
2. The other option is to install a mechanical limiting device such as a pop off valve or a regulator (Like the one in the posted link) These devices install into the air line to the MAP sensor and prevent the SES light by limiting the actual boost the MAP sensor recieves.
Costs around $20-40 depending on whether you buy one from a dealer, or piece it together yourself.
Old May 9, 2003 | 12:57 AM
Ghostrider304's Avatar
Ghostrider304
I've got a pop off valve on my truck, works great. It's worth the $30.
Later,
Will-
Old May 9, 2003 | 09:55 AM
cwb's Avatar
cwb
Well I hate to shoot your theory but I run about 32 lbs of boost (not all the time and mine only comes on with a full throttle 1/4 mile run. But I can hit it on the freeway and run it up to around thirty with no problems.
Old May 9, 2003 | 11:47 AM
cookie88's Avatar
cookie88
FTE Emeritus
Not so, I said you are limiting the boost to the MAP sensor, which is exactly what is happening on your truck. 32psi with no light means the MAP sensor is getting less than 24psi input.
Old May 9, 2003 | 11:54 AM
cwb's Avatar
cwb
Gotcha.
kidoo
Sep 19, 2011 07:26 PM
viperbluelx
16
Nov 3, 2009 06:03 PM
03_PSD
21
Oct 22, 2009 04:23 PM
StampedePSD
44
Jan 11, 2009 12:21 AM
radracer17
Jun 17, 2005 09:48 AM
