A/C compressor problem
Old Jun 23, 2012 | 02:33 PM
Cherie Mikus Henson's Avatar
Cherie Mikus Henson
Compressor will work fine if a jumper wire is used. As soon as wire is removed it quits. Checked fuses but still won't work.
Old Jun 23, 2012 | 04:00 PM
aquanaut20's Avatar
aquanaut20
One of the pressure switches is open, either low or high...
Probably LOW on refrigerant.....Philip
Old Jun 23, 2012 | 04:31 PM
Cherie Mikus Henson
Thank you. Will check refrigerant, we put some in not too long ago. Will it do that if too full?
Old Jun 23, 2012 | 10:36 PM
steve(ill)'s Avatar
steve(ill)
put a gauge on the line and you should have about 100 psi with motor off. Start up and engage clutch and the suction drops to 40 and high side goes to 200. If you drop to 20 or so, the switch kicks out. high side is probably over 300 psi to kick out.
Old Jun 23, 2012 | 10:52 PM
Cherie Mikus Henson
Thank you so much for the help. Will check tomorrow with the gauge. Thanks again.
Old Jun 25, 2012 | 10:14 AM
tangster's Avatar
tangster
You say you just recharged the system ? May be better off looking for the leak at this point if you just charged the system.. Look for wet oily spots on the O.Rings at all the connections points and all over the Condensor coil thats where I find most leaks as rocks will kick up and puncture the Condenser coil .
brobrad
1997 - 2003 F150
Sep 20, 2014 09:41 PM
husker16
19
Jul 26, 2012 05:51 PM
Harbinger
Jun 19, 2006 12:19 PM
rlbates
1983 - 2012 Ranger & B-Series
Jun 2, 2006 11:24 AM
Madeline
Sep 11, 2004 08:59 PM
