Flywheel rattling - 2000 Explorer
Old Jun 25, 2012 | 11:51 AM
jsims813's Avatar
jsims813
Originally I thought I had some bad gas, lots of vibration when put in gear or a/c turned on, till I crawled under the truck. Planning on pulling the starter off in the next few days to see if possibly the bolts to the torque converter are just loose. If not it will probably be coming apart for a replacement. Is this a common problem on these trucks. Mine is a 4.0 OHV engine. Also, I've read that Ford switched to a 2 piece flywheel/flexplate after 1996. Can I use an older solid one as a replacement. Not sure if it mounts with 6 or 8 bolts. Anyone who could give me some tips would be greatly appreciated. Thanks.
Old Jun 25, 2012 | 12:19 PM
shorod's Avatar
shorod
Are you sure it's not just a misfire?
-Rod
Old Jun 25, 2012 | 01:24 PM
jsims813's Avatar
jsims813
Pretty sure. Recently did a tuneup and have drained the gas I thought was bad and replaced with new gas and dry gas to be safe. The vibration is constant and seems to be coming from the lower area rear motor/front trans.
jcduerr
Oct 18, 2008 12:04 AM
Jet Lizard
Aug 30, 2004 07:09 AM
buldozr1
Engine Swaps
Apr 6, 2004 08:06 PM
torquemeister
Jan 2, 2004 04:18 PM
goodfoot
Aug 28, 2001 05:55 AM
