steering column parts
Unless you talking about the switch that is in the steering wheel hub. That is called the speed control switch
E4TZ 9C888-A
Green Sales Company - Obsolete Ford parts, Lincoln, Mercury parts Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts.* Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.
They show to have 32 on hand
when you search on their page, remove the space and hyphen
E4TZ 9C888-A
I realize you're trying to help, but I suggest you delete the info in post #3 .. because it's the wrong part number. Then I'll edit this post, take out all references to E4TZ-9C888-A
The factory installed speed control switch was E0TZ-9C888-A .. but Ford obsoleted it (no one has any). Then the switch was only furnished with the horn pad (13A805).
This is what, I assume, the OP is asking for.
1986 F150/350 & Bronco: There are three different horn pads (include the speed control switch), due to the various finishes of each.
EOTZ-13A805-A .. Horn Pad-Rosewood grain finish / Obsolete / Same: 1980/86 F100/350 & Bronco
E2TZ-13A805-B .. Horn Pad-Black trim / Marked: E2TA-13K802-BWA / Obsolete / Same: 1982/86 F100/350 & Bronco.
E5TZ-13A805-E (replaced E8UZ-13A805-B & C) .. Horn Pad-Black with wood grain trim / Obsolete / Same: 1985/89 F100/350 & Bronco & 1988/91 Econoline.
No Ford Dealer or obsolete parts vendor has any.
Celticcitation
16
09-26-2020 02:10 PM
MikeBomba
07-09-2017 11:23 PM
Your41Plague12
WTB - Parts & other
13
12-16-2016 02:38 PM
