Only odd thing about their plain, non-wood grain, non-cruise horn pad is it is the Econoline van style with trumpet icons on the ends of the horn bar and a smooth "Ford" emblem in the center instead of the relief carved one. I'm guessing this was a later replacement style since the vans used that wheel later than 1986?
I mostly grab nice cruise control horn pads at the junkyard since the buttons break and that is generally what people are looking for. I think I may have a plain black one or two laying around, next time I am at my storage I will check and see if I have anything that would help you out. I could also grab one next time I'm at the junkyard. It would sure be a lot cheaper...
E6UZ-3600-A (replaced D8TZ-3600-B & E4UZ-3600-A) .. Black Vinyl Two Spoke Steering Wheel - 15" diameter - Use with P/S / Obsolete
1978/86 F100/350 & Bronco; 1978/87 Econoline; 1988 Econoline before production date 2/1988.
M & M FORD-LINCOLN in Liberty NY has 1 = 845-292-2497.
-------------------------------------------------------------------- E7UZ-13A805-B (replaced D9TZ-13A805-A) .. Horn Pad-Black Camera Case Finish-Use without Speed Control / Obsolete
1979 F100/350, Bronco & Econoline from serial number EA0,001; 1980/86 F100/350, Bronco & Econoline; 1987/91 E350 Cut-Away; 1989/91 F59 Stripped Chassis.
