steering column parts
Old 06-23-2012, 10:55 AM
winemaker69's Avatar
winemaker69
winemaker69 is offline
I want to get a new horn/ speed control assembly for my 86 f-250. Where would be the best place to find one? Are new ones availible?
Thanks
Old 06-23-2012, 12:02 PM
82f100460's Avatar
82f100460
82f100460 is offline
Not sure what you mean by horn/speed control assembly. The Horn relay is mounted to the speed control control amplifier back behind the instrument cluster. Are those the parts you are referring to?
They are separate parts btw
Old 06-23-2012, 12:21 PM
82f100460's Avatar
82f100460
Unless you talking about the switch that is in the steering wheel hub. That is called the speed control switch
E4TZ 9C888-A
Green Sales Company - Obsolete Ford parts, Lincoln, Mercury parts Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts.* Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.
They show to have 32 on hand
when you search on their page, remove the space and hyphen
Old 06-24-2012, 12:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
E4TZ 9C888-A 1984/89 E/F150/350 & Bronco: Use with dealer installed electronic speed control only. Switch attaches to turn signal handle.
When you look up part numbers, you need to pay attention to details. Otherwise you may list the wrong part number, and then what happens if someone buys the part based on your info?
I realize you're trying to help, but I suggest you delete the info in post #3 .. because it's the wrong part number. Then I'll edit this post, take out all references to E4TZ-9C888-A
The factory installed speed control switch was E0TZ-9C888-A .. but Ford obsoleted it (no one has any). Then the switch was only furnished with the horn pad (13A805).
This is what, I assume, the OP is asking for.
1986 F150/350 & Bronco: There are three different horn pads (include the speed control switch), due to the various finishes of each.
EOTZ-13A805-A .. Horn Pad-Rosewood grain finish / Obsolete / Same: 1980/86 F100/350 & Bronco
E2TZ-13A805-B .. Horn Pad-Black trim / Marked: E2TA-13K802-BWA / Obsolete / Same: 1982/86 F100/350 & Bronco.
E5TZ-13A805-E (replaced E8UZ-13A805-B & C) .. Horn Pad-Black with wood grain trim / Obsolete / Same: 1985/89 F100/350 & Bronco & 1988/91 Econoline.
No Ford Dealer or obsolete parts vendor has any.
Old 06-24-2012, 09:44 AM
winemaker69
It looks like I will need to visit some junk yards.
Thanks all.
Celticcitation
16
09-26-2020 02:10 PM
MikeBomba
07-09-2017 11:23 PM
Broncodude646
WTB - Parts & other
04-21-2017 08:59 PM
Your41Plague12
WTB - Parts & other
13
12-16-2016 02:38 PM
bucks77ford
WTB - Parts & other
03-20-2013 04:27 PM
Quick Reply: steering column parts
