Will it swap?
Old Jun 23, 2012 | 07:18 AM
Labhound's Avatar
Labhound
Will it swap?
I see plenty of 300 fuel inj motors out there for sale, so I was thinking, are the motor mounts and bell housing the same as the carb models?, I just may go more modern in the old '82.
Old Jun 23, 2012 | 12:31 PM
AbandonedBronco's Avatar
AbandonedBronco
Yes. There are VERY few differences between the EFI and carb'd 300s. The blocks are nearly identical except that the EFI block doesn't have a provision for a mechanical fuel pump. The head has different shaped combustion chambers, and it has 3 extra bolt holes for the int/exh manifolds. That's about it.
If you do the swap, you'll need a higher PSI fuel pump, and be sure to look for one that has a manual transmission so that the onboard computer isn't looking for signals from the automatic.
Old Jun 24, 2012 | 12:19 AM
F-250 restorer's Avatar
F-250 restorer
IIRC, the EFI pistons are lower c.r. than the non efi years. If that bit of info turns out to be true, then if you use a non efi head, the c.r. would be even lower?
Old Jun 24, 2012 | 11:40 AM
VocaTexas's Avatar
VocaTexas
Ford 300 Inline 6
Looks like compression went up with EFI.
Old Jul 1, 2012 | 12:45 PM
Labhound's Avatar
Labhound
Well I found a 240 motor, complete with an extra carb for $150
Old Jul 1, 2012 | 02:38 PM
Labhound's Avatar
Labhound
I might just run the 240 for a while or just go ahead and swap a few parts bump it up to 300, using the 240 head and some other goodies.
Heck while the motor is out I'll freshen it up under the hood.
pete98cobra
Oct 30, 2016 12:03 PM
apachetech
Jan 30, 2012 05:17 PM
JoeDaf
Jan 19, 2012 01:35 PM
jeff gammon
Aug 18, 2009 06:56 AM
Onus
Jun 10, 2009 08:33 PM
