Sponsored by: Real Truck
Scan Guage II
Old Jun 23, 2012 | 01:14 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA
Scan Guage II
What are the 15 functions that it reads and who's running one??
Old Jun 23, 2012 | 01:49 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
functions?
way more than just 15. It has some pre-set...but you can custom program a metric butt-ton of them using the x-gauges here.
Had mine for about 8 months. Use it to read EOT and ECT every day
Old Jun 23, 2012 | 07:57 AM
Tugly's Avatar
Tugly
If you are looking to buy something, you might consider AutoEnginuity (link in my signature).
Old Jun 23, 2012 | 12:49 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the AE is my next toy to buy...but for driving around with gauges, you can't beat the Scangauge II
Old Jun 23, 2012 | 09:01 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
With the X-Gauge function, it can theoretically pick up any sensor on the CAN bus, you're just limited by what coding people have come up with to find them. Linear Logic (the company that makes the SCII) puts out several lists of engine specific codes, and there are more lists floating around the boards. Stock, it'll read basics like voltage, coolant temp, open or closed loop, map, RPMs, MPH, intake temp, ignition timing advance, and it has an MPG program.
I have mine programmed for FICM voltage, trans temp, oil temp, exhaust back pressure, baro, boost, trans temp, ICP, IPR%, a whole laundry list of 6.0L specific stuff. It's not hard, maybe 2 minutes to code in each gauge.
http://www.scangauge.com/support/x-g...cific-xgauges/
These are Ford specific, but I think there are more CANSF and OBD-II code lists that might have some x-gauges that work.
Turfzilla
Oct 4, 2012 10:58 AM
Tugly
78
Aug 27, 2012 06:43 AM
A/Ox4
Jul 11, 2012 06:11 PM
Diesel 724
Apr 13, 2012 06:20 AM
plow/truck
Nov 23, 2005 05:36 PM
